Old 10-05-09, 06:00 PM   #21
Default Re: FI light comes on after approx 20 miles
Depends, it only uses the O2 sensor for closed loop control when it's at cruise and needs that fine control over the mixture. AFAIK at varying speeds it reverts back to open-loop control so it doesn't mess about waiting for a steady O2 reading.
So it could be heat, or it could just put the light on when it wants to know what the O2 sensor has to say and can't find it.
Old 10-05-09, 06:50 PM   #22
ophic
ophic's Avatar
Easy enough to test surely - ride with resistor, ride without resistor (if thats possible and the resistor isn't just there to fool some kind of start-up self-test) - compare results.
What YC says sounds very likely- i wouldn't expect the engine to getting that hot on a steady motorway cruise. Plenty of aircooling for the engine and radiator. The resistor might even have burnt out and is doing nothing so get a test meter across it and see what's what.
Silver SV650SK3, Fuel exhaust
Old 10-05-09, 08:52 PM   #23
stevebetts
That makes sence YC.
What in your opinion is the best solution?
I suppose i could have a hole put in the system and re attach the lambda sensor?
Old 10-05-09, 08:55 PM   #24
stevebetts
I am pretty sure if i take resitor out the FI lights imideately - i will test it when i get chance.
I agree, YC makes good sence.
Old 10-05-09, 09:55 PM   #25
Get a bike with carbs on.
Or a TLS that doesn't have a lambda sensor
A resistor isn't generally good, what is it telling the ECU at cruise? Lean/rich? Certainly not conducive to proper control.
First I'd look at where you got the advice to use a resistor, how do they avoid this issue?
Can a reflash of the ECU tell it to use fully open-loop control?
Can you fit an early ECU that doesn't have the pesky sensor?
Then look at welding a boss into the pipe.
Old 10-05-09, 10:04 PM   #26
ophic
ophic's Avatar
No worse than bikes that don't have them. Carbed bikes have been managing without for years. Afaik pointy 650s don't have them either.
Old 10-05-09, 10:06 PM   #27
Yes I am aware of that.
However the ECUs of bikes not so equipped are not expecting a signal, and not trying to interpret a fixed resistance as something that it is not.
Old 11-05-09, 08:13 AM   #28
stevebetts
The bike came with the exhaust system fitted and therefore the O2 disconnected.
I notice when you buy a PCIII it comes with basically the same thing.
I dont know how that deals with it.
I dont know if its possible to tell the ECU to use open loop control.
I will have to do some digging.
Old 11-05-09, 11:06 AM   #29
Yeah find out, it might be possible to get it on the yoshi box and flash the ECU.
Since you've got a full system, a remap wouldn't hurt anyway...
Old 11-05-09, 03:59 PM   #30
stevebetts
been in touch with Dynojet today as they use the very same O2 sensor eliminator.
They were very helpfull.
They have the same issue - the trick is to remove cable 17 from the ECU (this is year dependant) to stop getting the FI warning.
They sent me the instructions showing this. If anyone wants a copy let me know and i will send it.
OMG! 143 miles until fuel light 53mpg! I'm_a_Newbie SV Talk, Tuning & Tweaking 22 26-06-08 12:06 PM
125 Miles Until Fuel Light, Yippee I'm_a_Newbie SV Talk, Tuning & Tweaking 13 14-05-08 12:03 PM
180 miles and no fuel light... Tiger 55 Bikes - Talk & Issues 21 09-07-07 06:25 PM
IMPORT SV 650 year 2000, 8500 approx miles done (12451). thegripper For Sale - SV's and SV related items 5 09-03-07 08:14 PM
82 miles until the light went on! and other stuff localhost SV Talk, Tuning & Tweaking 25 04-04-06 12:22 PM
