#21 | |
If so almost certainly a faulty side stand switch or clutch switch. You can test this by bypassing them with a peice of wire or a paper clip across the terminals of the plug they connect into. Start with the clutch switch. Unscrew it from the bar and see if you can reach the plug that connects it. If so disconnect and short the terminals on teh loom side and try to fire the bike up. Was anything else obviously damaged? Is the nuetral light illuminating when you attempt a start? |
#22 |
It fell onto its left side hence the new gear selector pedal and clutch lever (also made a bit of a mess of the fairing, bar ends and indicator)
Neutral light comes on....in fact everything looks fine except no turn over Do you think the battery could be shagged? |
#23 |
Probably the clutch lever switch is borked.
#24 |
Yep, my money is on the clutch switch. SHort out as I mentioned above and see if it starts.
Its possible the battery is goosed, check it hasnt leaked battery fluid. If you have a set of jump leads connect up to your car battery with the car engine not running and try the bike again. Most likely that clutch switch though. |
#25 |
Is the starter button dead, or is it turning and not firing?
#26 |
bypassed the clutch switch and I now have rapid clunking from the starter (as if the battery isn't charged up enough) so am gonna leave it charging overnight and try again tomorrow morning
Its definately a goosed clutch switch but is probably a goosed battery too Its not been a good week Thanks for everyones help - hope to meet you on a ride out soon |
#27 |
![]() ![]() hopefully the battery will recover if not get a new one! |
#28 |
SHE STARTED!!!!!!!!!!!!!!! WOOOHOOOO!!!!!!!!!!!!
Guess I just need a new clutch switch then! Anyone now where I can get one from? Thanks chaps |
#29 | |
Alternatively I'm sure I have a clutch switch here you can have. I'll post it over. Last edited by flymo; 06-06-09 at 07:53 AM. |
#30 |
I think i'd better replace the clutch switch as I am the sort of idiot who would just end up crashing through a shop window at some point without it, lol
Thanks for the offer flymo, it's really decent of you.. if you have one spare I'd like to buy it from you as I can't find one on ebay or on banditmania / busters. ![]() ![]() |
bike wont start, help! | stanie | SV Talk, Tuning & Tweaking | 15 | 31-03-09 09:39 PM |
Bike Wont Start Need Some Help Lol! | sv650k4 | Bikes - Talk & Issues | 56 | 29-01-08 08:17 PM |
Clocks start spinning and bike wont start?! | lockery | SV Talk, Tuning & Tweaking | 4 | 13-04-06 07:32 AM |
My bike wont start - why? | SV Ste | SV Talk, Tuning & Tweaking | 6 | 01-12-05 08:23 PM |
Bike wont start!! | Robbo_ | SV Talk, Tuning & Tweaking | 9 | 31-08-05 07:46 PM |
