Old 21-07-09, 05:39 PM   #21
Rocket
Default Re: Tyre pressure loss?
Originally Posted by Spanner Man View Post
The loss of a couple of PSI per week is normal.
I don't agree with this statement. The current tyres on my 03 thou are holding a steady 36psi for months on end. I hardly ever have to pump up the tyres on my car either.
There is a leak somewhere, albeit a slow one.
Puncture
Leaking valve core
Leaking valve
Leak between tyre and rim
Porous rim
Old 21-07-09, 07:04 PM   #22
Spanner Man
Puncture
Leaking valve core
Leaking valve
Porous rim
Well you must be the lucky one then Or perhaps I should have been more specific & said 'could be considered normal'
After all why does one think that manufacturers specify that you should check your tyre pressures weekly, or every 200 miles?....Cue for some 'handbag flinging'
Check 'em weekly folks we can't all be as lucky as Rocket!
Cheers.
Spanner Man
Old 22-07-09, 01:53 PM   #23
Sir Trev
Sir Trev's Avatar
Cheers.
Mine hardly ever lose more than a PSi or so here and there (atmospheric changes probably) but I always check them before every ride! That one time I don't check may be the time I ride off with damage picked up from the last ride that's already dropped the pressure to half the recommended...
Old 22-07-09, 04:03 PM   #24
Lissa
Just Ballast
Lissa's Avatar
We used to always lose pressure, both on the SV and then on the Duke............until we used a different tyre fitter. Now we can go weeks with no loss of pressure. What the new fitter is doing different to the old one, I don't know, but the difference is very apparent.
Old 22-07-09, 07:23 PM   #25
Soap or new valve cores maybe.
Old 22-07-09, 09:00 PM   #26
MattCollins
Perhaps he is a little nicer to the bead area... I am no tyre fitter but I get to fit and balance all of my own bike, car, truck tyres (less of the latter two) and learned the hard way that reasonable care needs to be taken with the beads.
Old 22-07-09, 09:28 PM   #27
flymo
flymo's Avatar
Totally agree MattCo. Fitting tyres is one of things that only needs doing once if you do it properly. If the rims are cleaned properly and the tyre is soaped before fitting you should get a pretty good seal on a straight rim.
I fit all my own race tyres, the only issue I've ever had with pressure loss has been a faulty valve core once.
Tyre Pressure hindle8907 SV Talk, Tuning & Tweaking 6 23-06-09 08:53 AM
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
What's your tyre pressure? Diveboy SV Talk, Tuning & Tweaking 28 03-05-06 07:05 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
