Old 20-08-09, 10:16 PM   #21
CarlosSV650S
Default Re: The SK9
other option then is to drill it out, and get a suitable size nut and bolt to replace incase you need to put it back in.
Old 21-08-09, 06:38 PM   #22
Gene genie
Default Re: The SK9
Originally Posted by matt c View Post
Matt C
think it looks the dogs in black. your clocks are showing full ''8'' figure digits as they do when you first switch on, however the first digit has a section missing. is this normal. i'm asking because its the same as mine and i thought my clocks were on their last legs.
Old 22-08-09, 06:59 PM   #23
Nobbylad
Nobbylad's Avatar
Default Re: The SK9
Get a small gauge centre punch and give the rivet some solid thumps in the centre, then drill out the rivet. If the baffle is tight and won't budge with some decent sized pliers, give it a squirt of WD-40 or similar, leave for a few mins then attack again with pliers, with some twisting.
Once it's out, wrap in an old rag, stuff in a small plastic bag and shove under the seat along with a suitable sized selt tapping screw or bolt so that if plod ask you to put it back in, you can.
Removing the baffle is a safety feature that allows road users who haven't seen you, to hear you!
Old 24-08-09, 01:57 PM   #24
matt c
Default Re: The SK9
Yeah has been like that since new, and my SK4 was exactly the same.
haha, everyone is so determined that I should take it out.
