#21 |
I can't imagine it being unsafe as long as it was done by some one competent enough. I think that I am good enough to machine it my self and b accurrate enough to make sure it was correct.
#22 |
And what is bending moment on forks under "oh dear, I'm going to die" braking conditions? What force does this translate to at yokes?
Personally I wouldn't do it. Making new lockstops is a bit of a PITA too, remember if you use the old yokes and new forks you then get issues with fork spacing and whether the brakes line up right.
#23 |
Yah 50mm top 54 bottom
#24 |
All personal choice =]what I see as an acceptable risk others may not agree fine by me its not them thats using the yokes
#25 |
Indeed, I think it's fairly stupid though when a £20 part avoids this severe risk and a lot more issues besides though.
The reason the SRAD swap is so common is because it is simplest for the greatest gains.
#26 |
I am a cheapo =]
#27 |
your a silly silly boy
#28 |
If you were going to go proper mad just based on performance you'd probably end up with GSXR600/750 K7ish fork bodies with traxxion internals and some of those blue-spot R1/R6 monoblock calipers. Ker-ching!
Problem with SRAD stuff is discs warp. I think TSM has done like 3 sets of them! But speedking does some frikken gorgeous remakes of these for much cheaper than EBC/galfer. I digress... Personally I would not want to spend 4 hours or so machining stuff to end up with parts of a lower quality, far higher weight and dubious strength. If you are going for performance then go for it.
#29 | |
The Sick Man
yup ive messed up a load of disks, i think they are more bent than anything i just had one pair straightened by motoliners last week, but i need to take them back as one of the disks was not dead true, should be all ok aparently flat disks can bend so easy, especialy as i wheelie a load and loads of pot holes in london and on the latest set of disks i had a suffed bottom bearing now with thoes things sorted out, everything seems so much better
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#30 |
Yes speedking from US.
I think it is stockers do not have enough clearance in rivets so heat creats a twist because inward expansion is not allowed. For momentum of discs to cause issue they'd have to be fired out of a cannon at something! Let me know how you get on with the motoliner'd discs, I've got a set to sort myself.
Pointy/Curvy wheels are they interchangable? | Owenski | SV Talk, Tuning & Tweaking | 2 | 17-10-09 10:01 AM |
USD GSXR1000 k1 forks | standed forks - curvy | Nicky S | SV Talk, Tuning & Tweaking | 113 | 07-09-09 01:12 PM |
curvy forks | husky03 | For Sale - SV's and SV related items | 5 | 29-10-08 07:10 PM |
Powercommanders - are they interchangable? | Jase22 | Bikes - Talk & Issues | 4 | 13-01-07 05:06 PM |
SRAD and ZX6R shocks interchangable? | mysteryjimbo | Bikes - Talk & Issues | 8 | 21-06-06 12:14 PM |
