Old 23-02-10, 11:40 AM   #21
Dave20046
Dave20046's Avatar
Default Re: Running like a dog.
ársehole
Old 23-02-10, 11:40 AM   #22
Owenski
varients of A R S E seem to get through the swear filter
Old 23-02-10, 11:41 AM   #23
Dave20046
Dave20046's Avatar
yeah it does arsed is ok, arsing also maybe but an outright **** is not. Ass is fine though for the southerners/yanks.
Old 23-02-10, 11:41 AM   #24
If you want to get those nuts off, grind through the side of threads with die grinder or dremel, then tap nuts around with punch. That will remove any problem nut.
then to get studs out plusgas them to death for a month. Heat them, blast them with freeze and release spray. Heat the head casting with a wet rag around the stud and then attempt to remove.
Old 23-02-10, 12:48 PM   #25
Owenski
Following what you've both said I've done a little reading and it seems this isnt uncommon at all.
Im thinking I may be better admitting the bolts wont come out easily and starting by doing what you say YC about using the dremel to remove the nuts taking off the header pipe and then dremel again to cut the bolt to get a nice surface across it. Then drill a small hole in the end and use one of these http://www.screwfix.com/prods/20084/...actor-Set-8-Pc to get the bolts out and obviously replace the bolts with some nice new ones bathed generously with copper slip.
Old 23-02-10, 12:50 PM   #26
AndyBrad
matt. i've got one of those stud extractor sets. i would advise that you try every possible way of getting it out before you use one. there not that cracking...
Old 23-02-10, 12:52 PM   #27
Dave20046
Dave20046's Avatar
No it's very common. My curvy one was a bit of an árse (and it was pristine/garaged all its life!), YC did me some stainless studs (which I also copperslipped).
Old 23-02-10, 05:09 PM   #28
Do not use a stud extractor except as a last resort. Those cheap ones are wucking fank. And you will be looking at getting the broken extractor spark eroded out of the head because they're harder than everything except cobalt drills!
Get a socket type stud spanner on them, lots of heat, lots of oil, lots of heat/cooling cycles and penetrant oil. Patience is the key.
Think about it, what is going to be stronger? 4mm dia stud extractor, or 8mm dia stud? You want to try and move the 8mm dia stud every time.
Old 23-02-10, 05:28 PM   #29
fastdruid
fastdruid's Avatar
A suggestion is to weld a bolt head onto the end, double wammy of giving something to try and turn it with and the heat of the welding hopefully breaking any corrosion seal.
Druid
Running bad bobbleheadbarne SV Talk, Tuning & Tweaking 4 25-12-09 06:50 PM
Not running well now 5hort5 SV Talk, Tuning & Tweaking 13 29-11-09 03:13 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
Running on one? Tzindo SV Talk, Tuning & Tweaking 24 07-04-08 10:06 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
