Old 25-02-10, 02:08 PM   #21
chris8886
chris8886's Avatar
Default Re: 2008 ZX10 Shock fitted.
High tensile bolts is the techy term, i just got them off my brother
so the first time you ride it hard round a bend then it's going to break and through you into a hedge then? we know what brothers are like!
AR08 to AR13-QUALITY!
Old 25-02-10, 05:25 PM   #22
Wideboy
Evel Knievel
Wideboy's Avatar
rofl, yeah now yo come to mention it
05 DRZ400E
RIP hovis
Old 25-02-10, 05:36 PM   #23
Mr Speirs
Mr Speirs's Avatar
Apparently High Tensile and High Shear are two different things...that said I just got a high tensile bolt anyway and had no issues
You don't need a smaller battery, just cut the (obsolete) battery stay off the tank hinge and tip the existing battery on its side and make sure the pos and neg cables are loose enough to reach. Simples.
Old 25-02-10, 05:41 PM   #24
Wideboy
Evel Knievel
Wideboy's Avatar
meh both do the same job tho lol
cheers Brittany i'll give that a go on sat
05 DRZ400E
RIP hovis
Old 25-02-10, 06:57 PM   #25
Old Git
Old Git's Avatar
WB, looks good, where did you find the info on the compatability between the SV & ZR shocks.
I was advised thus
"Just because it may "fit" doesn't mean it will work properly. The hole to hole could be the same length, and the bolt holes may be the same size, but if the linkage & triangles, even the swingarm & frame mounting location are different, than the spring and dampening rates would be completely off. Even a small difference on mounting location and linkage rates could end up being a big difference in the spring & dampening. Would could end up with a shock that bottoms out as soon as you sit on the bike, or one that doesn't allow the bike to move at all."
So is there somewhere I can look for details on options on my Falco, or was this something you have copied from someone who already did it & so knows it all works out.
Ta,
Old Git is offline   Reply With Quote
Old 25-02-10, 07:16 PM   #26
Wideboy
Evel Knievel
Wideboy's Avatar
YC had a chart but i cant remember who it was, something racing. I used one that CheGuevara put up but it only covers sv compatible shocks (im assuming) as it only lists suzuki and kwak
the shock i have is the same strength as the standard one (bought in confussion as i was looking at wrong shiz on teh chart ) but with a little bit of tinkering it should be an improvement
i sort of bought it with the attitude of "well feck it, if it wont fit, i'll make it fit" but it fitted
05 DRZ400E
RIP hovis
Old 25-02-10, 08:11 PM   #27
-Ralph-
I was advised thus
Ta,
The linkage controls the leverage on the shock and the ratio of rear axle movement, versus shock movement and whether or not this is linear or progressive.
If you put another shock in that is the same spring rate as the original shock and the same length as the original shock, in those respects you don't change anything and the shock will be compatible, so long as they physically fit.
Damping, compression, etc may need to be set differently on the SV as it would on it's donor bike, but hopefully you are swapping for a shock where those are adjustable.
Most people wouldn't want to change for a shock with the same spring rate as standard however, unless that just happens to suit you perfectly, so there is a calculator on Race Tech's website that tells you for your weight, with the standard linkage on your bike, what spring rate you'd need on your new shock.
Cheguevara's table gives the spring rates and lengths for common shocks that physically fit.
Old 25-02-10, 08:40 PM   #28
I was advised thus
Advised by who? There's a few shocks bolt up and work better than stock, mostly because that's a very low height to set the bar at
Falcow owners forum? If it uses same shock as mille that might be an option.
All bumf about linkages etc. is just to get a working spring rate at the wheel. You don't feel what spring you have fitted, you could have a million pound per inch spring feel exactly the same as 1 pound per inch spring if the linkage allowed it.
Old 25-02-10, 08:43 PM   #29
The OEM shock isn't compatible with the bike
Rebound dampings job is to control the spring, which being pretty beefy can store a lot of energy. The rebound damping needs to release this in a controlled way.
Luckily for us if 2 bikes need the same spring rate they will need broadly similar damping.
But bear in mind that adjustment is not full adjustment, you have a working range and if your needs are outside that then you'd have to revalve the shock to get it back within a working range.
ZX10 shock fitting problem. sprocket SV Talk, Tuning & Tweaking 26 10-03-10 09:09 AM
ZX10 Shock on a Curvy TheShadow SV Talk, Tuning & Tweaking 27 15-06-09 10:33 PM
ZX10 rear shock advice [yet again] tonny006 SV Talk, Tuning & Tweaking 7 22-09-08 04:49 PM
zx10 shock skapegoat SV Talk, Tuning & Tweaking 10 20-01-08 10:02 AM
ZX10-R '04 Rear Shock - Curvy Upgrade pmapp For Sale - SV's and SV related items 5 01-10-07 09:02 AM
