#21 |
see those spring rate numbers?
lb/inch (sometimes give # sign).... if you have a 1lb/in spring it means it will compress 1 inch if you put a pound of force on it. See how 1gen has 510# and 2gen has 430# spring? That means if you put that 2gen hagon in there it will likely be much too soft. Quality is important, but only if the raw numbers are pretty damn close to correct. There is a WP race shock for sale from GSXR600K2, brilliant quality, but will make your bike handle like crap because it is built for something different.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 08-06-10 at 08:11 PM. |
#22 |
My tuppence worth,I just replaced the front springs with Hagon and thier oil plus their rear shock running on their settings,the K5 is transformed,cost a bit but I now have the most perfect machine of my 10 years riding.
#23 | |
![]() p.s. where in leeds/halifax area are you from? |
#24 |
wheatley, halifax.
went to uni in leeds.
#25 |
am i right in saying an 03/04 gsxr 1000 shock will be good enough for my svsk3?
if im wrong tell me, any ill leave technical mods for a later date. =D |
#26 |
#27 | |
.... But no one ever does. C |
#28 |
Depends on change in spring, if it is way different then valving will be wrong
#29 |
Agreed. But a top shelf shock has enough adjustment to handle +/- 2kg per cm in spring rate
#30 |
You figured out what spring is on that WP of your yet?
Rear shock to fit K3 650? | rude | SV Talk, Tuning & Tweaking | 4 | 25-12-09 09:44 AM |
Wp rear shock for gsx-r 750/600 k4/k5 | karen | For Sale - Other Bikes and General biking items | 0 | 16-05-09 01:14 PM |
K3 Rear Shock | DarrenSV650S | For Sale - SV's and SV related items | 1 | 15-06-08 02:58 PM |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
what rear shock | robertpog | SV Talk, Tuning & Tweaking | 2 | 16-02-05 03:38 PM |
