Old 07-01-11, 08:16 PM   #21
bigchris
Originally Posted by Biker Biggles View Post
Just a thought,but is your air filter OK?Not clogged up,and there is a bit of insulation matting glued to the underside of the tank.Make sure it isnt loose and falling across the air intake when the tank is in place.
Air filter is fine, its brand new. Bike was back firing with airbox off as well?
Old 08-01-11, 11:12 AM   #22
bigchris
Sorted it!! Carb rubbers at cylinder heads loose and front carb balance line was sucking air in ( only a tiny amount though i think ).
Tightened rubbers up and replaced carb line with some fuel injector pipe and fuel clips.
Found leaks using wd40 and listening for a change in engine note.
Jobs a good un!!
Cheers for all your help
Old 08-01-11, 11:14 AM   #23
Default Re: Bike running rough!
Good well done for persevering
Old 08-01-11, 11:29 AM   #24
toxic
Well done mate!
Old 11-01-11, 06:31 PM   #25
bigchris
Arrrghhhh!! engine is now trying to die when i blib the throttle but pulls ok when throttle opened smoothly??? Is this an ignition problom? I did grease up the front cylinder to avoid it cutting out in the wet and am wondering if grease has got in the cylinder head? Last time i pulled the front plug out it was clean though??
Im ready for smashing it with a hammer!!!!
Old 12-01-11, 05:29 PM   #26
bigchris
Default Bike still running rough.
My bike is still not running right and im stuck.
Symptoms - bike is trying to stall at idle when hot. Idle is around 1300 rpm. Oil and petrol light flickering ( with idle at 1300 ) constantly when in traffic.
Throttle response is crap.
Things checked - plugs & leads checked for spark gap and condition, both good. No damp or crap.
isoproponol added to fuel.
Carbs checked for air leaks at every pipe and joint using wd40.
Engine oil level good.
I really am stuck now, is there anything ive missed??
Cheers in advance. :-/
Old 12-01-11, 05:53 PM   #27
tom-k6
Default Re: Bike still running rough.
have you checked your floats? maybe some carp has got in there and is buggering up fuel supply,
Old 12-01-11, 05:56 PM   #28
Biker Biggles
Biker Biggles's Avatar
Theres so many different threads on this now ive lost track.What is the symptoms and what have you checked/eliminated?
Old 12-01-11, 05:59 PM   #29
fastdruid
fastdruid's Avatar
Check your earths.
Druid
Old 12-01-11, 06:00 PM   #30
sweepdoggydog
Try changing the plugs, sometimes they look to be ok when you check them but don't function properly when they are insitu.
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Bike running rough at low speeds Grinch SV Talk, Tuning & Tweaking 11 24-11-06 09:20 PM
