Old 17-08-11, 07:34 PM   #21
Dicky Ticker
Default Re: New chain & sprockets - new whining noise?
I do not mean by ridiculous amounts but it is better to have a chain slightly loose than slightly over tight. My bike chain only runs quiet at the top end of adjustment.
Have you given the chain a good soaking in oil?----not just a spray, as not all new chains are properly lubed.
Old 18-08-11, 05:02 PM   #22
Rocket
I'd go with the chain being too tight as well. Diane adjusted her new chain and it howled like a banshee as she drove off for work. Slackened it off a few flats on the adjusters and the noise was almost gone. It won't take you long to try it out.
Old 18-08-11, 05:25 PM   #23
Originally Posted by trail guru View Post
Wheel/sprocket alignment was set using the scales on the swing-arms, first ensuring that the triangular-shaped widgets with the alignment markers were seated centrally on the axle.
I know they're a pretty crude but that's all there is. And, more anecdotal opinion from biker mates, alignment doesn't have to be spot on.
I don't use those marks, i count the number of turns I make on the adjustment bolts
Old 23-09-11, 12:02 PM   #24
trail guru
The chain's done nearly a 1000 miles now and the whine reduced over time to barely noticeable. I then adjusted the tension to about 20mm and the whine came right back. So backed it off to just under 30mm (about 1/3 turn on the adjusters) and the whine's reduced.
I guess some chains whine and I also guess that better have the chain too slack than too tight.
Chain and sprockets Endellion For Sale - SV's and SV related items 5 27-02-10 07:21 AM
New chain and sprockets- "whirring" noise twopots SV Talk, Tuning & Tweaking 4 20-08-09 10:55 AM
chain + sprockets? lancasterlad SV Talk, Tuning & Tweaking 2 06-08-07 08:01 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
Chain and Sprockets.... 650newb Ancillaries 3 28-07-05 05:25 PM
