#21 | |
Looks like I need a FH008 as I use the pillion dump
#22 | |
see this thread http://www.svrider.com/forum/showthread.php?t=130182
#23 |
annoyingly my fuse boards are mounted in on the seat rail and the stebel harness is there too
#24 |
Bit of a left field idea
Would a ZX6 J2 or RSVR (99-03) work? The ZX6 code is: sh650-12 and the RSV Code is: SH5416-12
#25 |
As far as I was aware you don't want the SH shunt models...
#26 |
You probably already did a check but thought i'd pop this fault finder on just incase you missed it. G
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
#27 |
if thats the case, its getting a pattern unit if I have no luck tomorrow
#28 | |
makes more sense than the haynes
#29 |
Update time
Just done the battery check and everything's come back with normal voltages Carried it out with the lights on and the voltage dipped then came back (but that maybe through the tester slipping off the terminals). Am I just being a fanny and its all alright or am I looking in the wrong area ![]()
#30 |
Wiring and battery condition - or you're a fanny. I can't decide which I'd check first.
Most importantly what exact problem are you having? PS Headlight brightening when revving is a hopeless test of regulator-rectifier, far more often caused by a low, or poor condition battery.
Heatstroke - Symptoms and treatment in dogs. | Samnooshka | Idle Banter | 3 | 04-07-09 11:58 AM |
Crash.NET - Stoner 'feels better', wary of symptoms. | NewsBot | News | 0 | 01-07-09 02:40 PM |
Obvious New Item of the Day | SoulKiss | Idle Banter | 7 | 20-01-09 06:33 PM |
Oh dear... Take these symptoms and... | northwind | SV Talk, Tuning & Tweaking | 13 | 14-07-08 10:37 AM |
Haggling if a bike has no obvious flaws... | Bear | Bikes - Talk & Issues | 64 | 21-11-07 09:04 AM |
