#21 |
Can someone confirm if Winder has spent money without needing to?
(Yes is the preferred answer.) |
#22 |
That has never happened Laurie
"Somewhere between happy and total f**kin wreck" |
#23 | |
An engine never turns perfectly evenly, the firing pulses are a finite distance apart, thus the engine slightly speeds up with each pulse and similarly slows down between them, the slower the engine speed the greater the interval between pulses, and obviously the reverse is also true, thus the force applied to the chain as the engine turns is not consistent and this is most noticeable at tickover.
#24 |
. . . and is FAR more noticeable with a V-twin ( or a single )
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#25 |
20k miles and a front sprocket with shark fin shaped teeth I think it was due a change
#26 |
Precisely so. The fewer the cylinders the further apart the pulses at any given engine speed. That's why, mostly, big motors with lots of cylinders - 8 or more - are so silky smooth, the pulses are closer together thus the cyclic acceleration and deceleration of the engine is less apparent.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 04-10-13 at 10:34 AM. Reason: Messed up the quote. |
#27 |
2800 cubic inch (roughly 45,900cc) 18 cylinder twin row radials are so smooth they can blow one cylinder right off the crankcase and nobody will notice until they see it missing.
Jumping speedo | Mads_DK | SV Talk, Tuning & Tweaking | 6 | 11-07-10 09:43 AM |
Chain Jumping after adjustment | kd80 | Bikes - Talk & Issues | 13 | 19-05-10 10:35 PM |
jumping out of gear | AndyBrad | SV Talk, Tuning & Tweaking | 15 | 12-05-09 09:47 PM |
jumping out of 2nd :-( | The Laughing Assassin | SV Talk, Tuning & Tweaking | 10 | 24-06-08 12:27 PM |
Cliff jumping! | ClemsonSV | Idle Banter | 7 | 25-07-07 02:23 PM |
