Old 08-01-14, 01:41 PM   #21
Alexander94
Default Re: Not selecting neutral when stopped
I've tried adjusting it and that seems to have helped a bit, I've spent about an hour trying all sorts of different positions and it's still not right though... Also there's more play in the adjuster than I previously thought, looks like I may need to replace the worm gear then :/
Atassiedevil: I can get second with a blip of throttle then I can get neutral from there with another blip of throttle. It's still pretty tough to get it up into second though, i have to force it :S
Old 08-01-14, 11:22 PM   #22
Ruffy
Ruffy's Avatar
Is your idle speed set right (c.1200-1300rpm from memory)? Too low can cause difficulties selecting neutral. Perhaps try tweaking it up to see if it makes a difference?
I presume changing gear whilst riding is OK?
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 09-01-14, 12:18 AM   #23
Alexander94
It may be a tad low but i couldn't really say, I only got the bike very recently and I had a ZXR400 before and it's quite hard to compare the 2 :P
Changing up whilst riding is fine but for the down shifts i have to match the engine speed to the road speed to get it to change, as if I was riding without the clutch almost...
I've been looking at replacement worm gears. And I noticed something, the rubber spacer/buffer (or whatever the proper name for it is) at the base of the gear where it meets the arm seems to be very warn compared to how it was on a brand new kne that I saw. Could that possibly be what's causing the problem? I was thinking about trying to replace the piece of rubber and seeing if that makes a difference
Old 09-01-14, 05:09 PM   #24
ChrisCurvyS
ChrisCurvyS's Avatar
I had exactly the same problem as you and it developed in the same way Sid Squid describes.
I put off sorting for ages and kept readjusting to stop it dragging without slipping but one of these:
http://www.ebay.co.uk/itm/05-Suzuki-...-/181244733422
- and 20 mins to fit is all it took to put right.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 11-01-14, 05:20 PM   #25
Alexander94
I'll replace it if i can't get it to work with more adjustments. I've found a replacement that's £10 but it's off a K5, does anyone know if that'll fit the '02 model? :S I also want to know whether the rubber at the back being worn will be making a difference, cos if it does I might try repacing the rubber and see if that solves it or at least helps (the one on mine seems pretty worn compared to how it should be new...)
Old 12-01-14, 09:36 AM   #26
If it's knackered it knackered - the rubber won't matter, and the fact that it needs such faff to get the adjustment right means it's clearly worn - replace it.
K5 lifter fits fine.
Old 12-01-14, 10:33 AM   #27
Alexander94
Ok, thanks very much!
Old 12-01-14, 10:36 AM   #28
Alexander94
That one was on ebay and someone else bought it... Now the only ones I can find are from america and they're a lot more expensive, they'll take ages to turn up and I'd run the risk of getting hit with import charges too... I know you're not meant to get charged for second hand things but I'd rather not risk it and just buy one from the UK :P
Old 12-01-14, 10:57 AM   #29
suzukigt380paul
why bugger about with secondhand parts,buy the part new,the CLUTCH RELEASE SCREW ASSY is only £45.50 from robinsons,and no doudt about the same price from your local suzuki dealer
Old 12-01-14, 01:36 PM   #30
Alexander94
I don't have much money atm so as it stands I can only afford a second hand replacement, if the replacement wears out too then I'll replace it with a new one if I can afford it at the time
Difficulty selecting 3rd gear. 1952paul0 SV Talk, Tuning & Tweaking 4 06-06-10 05:03 PM
My K8's not selecting 1st cleanly. schofs Bikes - Talk & Issues 16 23-01-09 10:41 PM
Trouble selecting 2nd Gear DanDare SV Talk, Tuning & Tweaking 9 06-05-08 03:36 PM
Sv neutral selecting tackle2004 SV Talk, Tuning & Tweaking 14 16-05-06 03:36 PM
Problems selecting Neutral. andy owen SV Talk, Tuning & Tweaking 11 20-12-05 04:04 PM
