Old 05-06-10, 03:18 PM   #1
1952paul0
Default Difficulty selecting 3rd gear.
my boy just purchased a new 650 he says he has difficulty in selecting 3rd. I rode it and it selected fine although i have to say going into 3rd its a bit clunky and was not entirlely smooth and i was on low speed roads. In a later conversation with him he said that it goes in at low revs but when the motors is reving harder its difficult. Has anyone else experienced this phenomenon. ATB paul
Old 05-06-10, 06:26 PM   #2
beabert
Default Re: 3rd gear
Could be clutch drag, but i find 2 is the gear thats usually worst, same symtom the faster the engines turning the more likely it wont slip into gear.
Is finding neutral with the engine on fairly difficult?
Old 06-06-10, 04:13 PM   #3
Bunks
Default Re: Difficulty selecting 3rd gear.
I had a similar problem. I think from memory people on here said to oil and check the chain tension. Seemed to do the job. Hope that helps.
Old 06-06-10, 04:57 PM   #4
1952paul0
thx for the replies slacked the chain off a bit and that seems to have aleviated the problem. I guess its in need of some miles on it to date its only done 120 odd mls. I must say i`m realy enjoying the forum once again thx and atb, Paul
Old 06-06-10, 05:03 PM   #5
120 odd miles I would agree it is not bedded in yet. Old suzukis were worse for that, I put brand new gearbox in my mates GS1000 and it was horrible box for about 500 miles. It got fresh oil at 250 and bit of steel wear was found, more fresh oil at 500 and no wear was seen... I rode bike again after this and gearbox was sweetest you have tried
Obviously worth keeping eye on chain and oil all time anyway.
Difficulty tightening rear axle nut ibriggs SV Talk, Tuning & Tweaking 3 16-02-10 11:59 PM
Trouble selecting 2nd Gear DanDare SV Talk, Tuning & Tweaking 9 06-05-08 03:36 PM
Pointy Speedos (Difficulty reading) Stu SV Talk, Tuning & Tweaking 9 19-04-07 09:13 PM
Engine stops when selecting a gear DanF SV Talk, Tuning & Tweaking 6 22-02-07 06:49 PM
gearbox not selecting gear correctly. DoubleD SV Talk, Tuning & Tweaking 5 30-08-06 02:22 PM
