#21 |
One very important point about the oil level.You simply must be able to check this.If you cant see the glass because the fairing is in the way,get the fairing off and keep it off so you can check this regularly.It is something that should really be checked every day you use the bike until you are familiar with how it uses oil, or not.Then maybe weekly will do.The cost of not learning how to do this is often a new engine.Not cheap.A quick search on this forum will reveal numerous threads where this has happened get that sorted first.
#22 | |
#23 |
100% agree with atassiedevil, ring them tell them to come and pick it up (dont attempt to ride it) and get them to sort it FOC
If for whatever reason this cant/wont happen, then look into fault finding. |
#24 | |
![]() Thanks alot for the info! ![]() |
#25 |
Okedoke- was going to ring them today and get it picked up
#26 |
Its got to come off one way or another.If you cant get the bolt out then get someone to do it for you,but like I said,you must be able to check that oil level regularly.You wouldnt ride the bike with a flat tyre or no helmet and having the right amount of oil is much the same.The oil level is point one on your checklist right now.
Curvy neutral light always on. | hounddf2 | SV Talk, Tuning & Tweaking | 1 | 04-05-13 07:50 PM |
Neutral Light for curvy | ricky_t | Bikes - Talk & Issues | 0 | 15-03-10 03:38 AM |
Me being a numpty - no neutral light and fi light is on | Whitehouse | SV Talk, Tuning & Tweaking | 8 | 03-04-09 03:50 PM |
Not going into neutral properly... | JakeRS | SV Talk, Tuning & Tweaking | 14 | 05-01-06 01:11 PM |
