Old 16-03-16, 01:35 PM   #21
Adam Ef
Adam Ef's Avatar
Default Re: Front brake lines help!
Might be worth asking SV_archie99 what length the standard ones are that he just took off his SV to put the longer ones in for the bar conversion he's doing... http://forums.sv650.org/showthread.php?t=221518
Old 16-03-16, 06:26 PM   #22
sputnik
Seems odd for a set of pre-boxed Goodridge cables to be the wrong length - does the part number on the boxmatch up with what is shown in the advert?
Bare in mind the hoses you posted the link to are (I think) for a front race setup - that is, the hoses go direct from the caliper to the master cylinder rather than having the extra section going over the front fender (as per the original setup). I don't suppose there would be any way of fitting them via the old set up but thought I'd mention it just in case that explained the apparent difference? I'm assuming your handle bars are the original ones too?
Old 16-03-16, 06:31 PM   #23
Eddie91
I cant see no part number on the box. Yes, this is race setup lines, but I have no clue what that means. Please explain. And I think my handlebars are original.
Old 16-03-16, 07:14 PM   #24
by the sounds/looks of it your brakes are fine but your fork seals are feked no sealmate is going to fix them.
due to your fork seals leaking your front pads will be feked and discs will be contaminated with oil.
my suggestions are:
get forks seals fixed pronto.
clean everything down with degreaser.
replace the pads but before you put the new ones in clean the discs with brake cleaner THEN put the new pads in.
Old 17-03-16, 04:36 PM   #25
sputnik
Just that the race one go straight up to the cylinder whereas the original ones have the h-shaped arrangement and are routed over the front fender via various t-pieces etc. You couldn't really mix the two up but I just meant to check that you weren't trying to follow the old path up to the cylinder or use the old hose guides but given that you say a mechanic has looked at them then I doubt that would be the problem.
Old 18-03-16, 06:20 AM   #26
Eddie91
Guys please!
What length front race brake lines need to be for 2008 unfaired/naked sv650! Seller is on my back.
Old 18-03-16, 08:55 AM   #27
tom_e
http://forums.sv650.org/showthread.php?t=144738
Old 18-03-16, 09:58 AM   #28
Red Herring
Red Herring's Avatar
Eddie, the race lines will be designed for a bike with clip-ons, i.e: low handlebars. I'd be very surprised if they went straight onto a bike with straight bars.
Old 18-03-16, 10:27 AM   #29
tom_e
HEL offer full race line setups for the N as well as the S so I imagine Goodrich probably do as well.
Old 18-03-16, 10:37 AM   #30
SV_archie99
Hi Eddie
Just to clarify I haven't yet sorted out the purchase of longer brake lines required for the my conversion.
The standard S brake line set up is on the bike with the single nose from the master cylinder and the split hose arrangement over the mudguard.
I'll be going out to the bike shortly to measure them up for you if this is what you need ?
Edit
Your looking at naked lengths which someone has supplied in the link above.
Pointy OEM front Brake lines kit sopeluk For Sale - SV's and SV related items 0 04-03-13 06:03 PM
2 or 3 front brake lines? SV Mad SV Talk, Tuning & Tweaking 5 02-06-11 02:02 PM
front brake lines shane hill Mini-Twins 4 21-03-09 11:23 PM
GSXR Front end brake lines andyb SV Talk, Tuning & Tweaking 2 17-01-07 09:23 PM
HEL SS brake lines (front) for k3.k4 SV650s echomadman For Sale - SV's and SV related items 0 25-11-05 03:57 PM
