Old 01-10-20, 10:32 PM   #21
svenrico
svenrico's Avatar
Default Re: 2020 sv650a comments
The c-racer seat is 30mm higher than the original Suzuki SV650A seat apparently, if anybody is interested.
svenrico is offline   Reply With Quote
Old 04-10-20, 08:58 AM   #22
gadget
Originally Posted by Craig380 View Post
I found a pair of cycling shorts with the gel insert (a tenner from eBay) to be an effective solution to SV @rse-ache. I can do 2+ hour stints quite comfortably now, which is as far as you'd want to go before needing a coffee / fuel / slash anyway.
Good call .... if you don't mind looking like Nicki Minaj ! Hahaaaa. 😂
gadget is offline   Reply With Quote
Old 04-10-20, 10:00 AM   #23
Seeker
Seeker's Avatar
Personally, I didn't like the design, but each to his own.
If I were to buy an aftermarket seat I'd go for either the Bagster:
https://www.silverstonemotor.com/en/...dle-5367z.html
or the Holeshot Performance:
http://www.holeshot.com/suzuki/sv/20...etfighter-seat
The guy at Core motorcycle seats (that did my seat) is a rider and will discuss your requirements. Having owned a Core seat for almost 4 years, I now know what I'd change if there's a next time.
My Z900RS has the low seat option which means they took out the foam. Getting off the Zed and onto the SV is like sitting on a cloud (no, not cold and damp - soft).
2016 SV650AL7
2023 GSX-8S
Old 05-10-20, 10:14 AM   #24
Bike27
I've got the Suzuki "Tuck and Roll" seat, I think the general consensus is any improvement in comfort over the stock seat is fairly marginal.
I find it absolutely fine comfort wise and would rate comfort better than stock, but then I appear to be in the minority by having also found the comfort of the stock seat ok.
Main issue I had with the stock seat was I found it too low and the "Tuck and Roll" option seems to add just enough extra height (somewhere between 5 and 10mm).
I also prefer the look so was pleased to be able to pick up an immaculate used one on ebay for around half the new price of circa £200.
Suzuki Tuck and Roll Seat
Stock
2018 SV650AL8
2001 KTM 640 Duke2
2015 KTM 390 Duke
Bike27 is offline   Reply With Quote
Pyramidplastics SV650A L7 hugger review Seeker SV Talk, Tuning & Tweaking 5 27-09-17 06:45 AM
SV650A L7 service manual Seeker SV Talk, Tuning & Tweaking 7 28-08-17 12:10 PM
SV650A L7 flyscreen Seeker SV Talk, Tuning & Tweaking 7 19-01-17 09:05 AM
SV650A 2016-2017 muffs UnoSD SV Talk, Tuning & Tweaking 3 04-01-17 08:28 AM
Sv650a l7 Seeker SV Talk, Tuning & Tweaking 9 28-06-16 09:15 AM
