Old 04-03-05, 05:30 PM   #21
Spiderman
Where the hell am I?
Spiderman's Avatar
I did the easier one.
Forget wire wool and any thoughts of a miror finish, use the rough side of a sink sponge in a motion up and down till it got most of the loose crud off.
Apply the autosol over the top of the now smooth but still brown pipe, polish.
Nice smooth finish to a brown pipe.
as much as i love your front pipe Jonboy, i just know i wont keep mine looking like that so i resigned myself early on to a routine i'd stick with.
Brown but smooth and clean.
Old 04-03-05, 06:00 PM   #22
Dicky Ticker
Default As per
I've got a Suzuki Bellypan [Kin expensive but Pyramid is good and a darned sight cheaper] Mine keeps the front pipe clean. I looked at the alternative,fitting lowers but if I had wanted a faired bike I would have bought something different from the SV The SV is one bike that a bellpan
looks right on and still retains its semi-naked look IMHO a good investment
Mac
Old 04-03-05, 06:24 PM   #23
jonboy
Steady on Zig old chap.
Old 05-03-05, 12:54 PM   #24
Spiderman
Spiderman's Avatar
Doh! PMSL
Old 07-03-05, 01:44 PM   #25
Ceri JC
Default Re: As per
Mac
Do you find the slight lowering in ground clearnece a problem? I don't exactly supermoto mine (stock suspension still ), but there are some fairly hefty speed bumps near me and I hope a bellypan won't affect clearence too badly. Ta for confirming it keeps the header pipe that much cleaner.
Old 07-03-05, 01:50 PM   #26
Scoobs
Default Re: As per
Mac
I have to bump mine up and down kerbs from time to time and I have never bottomed out my Pyramid belly pan.
Old 07-03-05, 03:19 PM   #27
I grounded my Pyramids one an absolute beauty riding down a parking ramp But Previous Owner's husband had decked both sides in corners, and gave it nice hero scars down the side. You'd have to be really going some though.
Old 07-03-05, 07:42 PM   #28
Stig
Okay Mitch here's what you do. Wash off the crap. Then use steel wool together with a metal polish like Autosol (or something like it) and just keep rubbing and rubbing till the corroded surface layer is eventually worn away. This will take forever BTW so be prepared to do this in several goes.
Now you should have a silver coloured pipe with a totally matt finish. If there are still marks on it then you need to go back to stage one.
Get a long strip of rag (about a metre by 5 cm) and then (after liberally coating the header pipe with more Autosol) loop it round the pipe twice so that you are holding both ends of it. Now push and pull in long regular strokes so that the rag is forced round the pipe. Gradually move the rag up and down the pipe while you're doing this adding more Autosol every few minutes. After about two hours you'll genuinely have a mirror finish.
Get a clean rag and wipe off any remains of the metal polish with a few vinegar strokes.
Oh and you'll sweat a lot . Good luck.
What a long and laborious way to do things Let me tell you the EASY way to do it. Cover the whole pipe with autosol or something similar Plug in your power drill with the polishing buff on the end and keep going and applying said polishing compound until you can see your face. Get a clean rag and wipe off the excess. Go inside make a cuppa put your feet up and think about the poor chaps that are doing it manually.
Old 07-03-05, 07:48 PM   #29
jonboy
You lazy swine you!
Old 07-03-05, 07:53 PM   #30
Stig
You lazy swine you!
Why walk when one can ride the bike
Why make a coffee when the mrs can make it for you
Why spend hours cleaning the downpipes when you can use a drill
blah blah blah
Autosol? xbox650 SV Talk, Tuning & Tweaking 18 18-05-08 07:53 PM
Autosol! plowsie Idle Banter 23 24-01-08 10:10 AM
where not to use autosol sv-robo Bikes - Talk & Issues 15 15-11-07 09:07 PM
Autosol Torn-Thorax SV Talk, Tuning & Tweaking 3 27-09-06 08:19 PM
Autosol WelshWop SV Talk, Tuning & Tweaking 11 05-06-05 11:28 PM
