Old 28-06-06, 10:50 AM   #21
jamesobrady
Default Re: Brake probs (with pictures!)
Originally Posted by goof
Lads am i missing something ? The problem is as above...pieces indicated one and 2, part of the casting, are protuding past the pad and contacting the disc?
Whats playing with the forks going to change?
You've got the wrong thickness pads no?
Right footprint...wrong thickness of pad material.
Or what am i missing?
Old 28-06-06, 10:57 AM   #22
Nah, those are the right pads. EBC HH FA229, IIRC. I had the same ones in mine.
Old 28-06-06, 10:58 AM   #23
TSM
The Sick Man
TSM's Avatar
Unlikley as that is a good amount of friction material, its not part of the casting thats protruding as the caliper is a floating unit and the bit that is sticking out does not move as its fixed to the fork leg and only the caliper body moves, but only a little, bits always run close to the disk, somtimes by a few mm.
Old 28-06-06, 11:24 AM   #24
21QUEST
21QUEST's Avatar
Did you find out what the problem is?
What pads(make are you using). Post up the Part number if you can as someone may be able to double check you have the right pads.
Alternatively can you post up a pic of the pad showing the rear of pads when installed in the calipers ie other side that can be seen in your first pic.
Ben
Right I've just gone out and got a set of caliper I've got lying around. It's been ages since I looked at a standard caliper.
Anyhows I think your problem may be the pistons may be stuck.
Ben
EDIT: Scrap that , I've had another look/think and I'm convinced the problem is pad related(backing plate too thick. It may appear counter-intuitive but think that's the problem. I've also done a comparison with a set of Nissin pads I've got and appears's that is the case. A pic would probably explain it better.
Nemo me impune lacessit.
Old 28-06-06, 11:27 AM   #25
Good won't have the number, but he got the pads off me... I might have an unopened pack still, I could get the number off that- but I got 3 packs at the same time and fitted one just fine.
Old 28-06-06, 12:13 PM   #26
21QUEST
21QUEST's Avatar
Aah... missed that before my edit. Hmm... that would throw my thoery out of the window then . Maybe just a rougue set
Ben
Old 28-06-06, 12:40 PM   #27
TSM
The Sick Man
TSM's Avatar
Its nothing to do with the pads or caliper at alll.
It cant be as its not the caliper thats damaging the disk, its the bracket which is a fixed item onto the fork leg eg making the fork leg the place to look.
Old 28-06-06, 12:59 PM   #28
This is great, it's like Guess Who.
Old 28-06-06, 03:47 PM   #29
Foey
Not trying to imply you're a numpty but did you remove the front wheel for any reason, if so did you put the spacer back in.
Old 28-06-06, 06:09 PM   #30
goof
Thanks again for all the replies - sorry I've not been about this savo to get back to you all, been busy with work stuff but I'm hoping to get out tonight and have a play. Tried the initial routine that Sid mentioned, didn't work so am going to trying HARDER!!! as suggested
FWIW, that side isn't the ones you sent me Northy, they are Armstrong HH I got for the other side. Will check codes when home.
Have had the front wheel off Foey but am pretty sure the spacer is there!
Brake light probs Baz SV Talk, Tuning & Tweaking 9 24-09-08 08:07 AM
reg rec probs maybe dizzyblonde SV Talk, Tuning & Tweaking 4 27-09-07 04:07 PM
more probs hovis Idle Banter 6 02-10-06 09:05 AM
Front brake probs, advice needed. Dirty Baz SV Talk, Tuning & Tweaking 14 21-03-05 04:18 PM
sticking brake pt 2 (got some lovely pictures ) *update* Warren SV Talk, Tuning & Tweaking 18 24-01-05 04:59 PM
