#21 | |
Connect battery +ve & -ve to pin 85 & 86 respectively. Between 30 & 87a you should see a continuous connection (diode test or resistance check on a DMM) only when the battery is connected. 30 & 87 should only have a connection when the battery is NOT connected. The starter relay might not have all these pins, and might not be labeled like this. Google "bosch relay diagram" for a picture of what I'm talking about. I suspect the SV starter relay would only have pins 85,86,30 & 87a (so it'd be a SPST - Single Pole Single Throw - relay). Wiring one up the wrong way around won't fry it, you just won't get the expected results. |
#22 |
I think that this is beyond me. The relay checked out. It is one clicking *******. So my options are running out, and to make the whole thing just a bit more confusing I tried to start the bike by bridging the relay and it just wouldn't start. I think my battery was starting to run low I was turning it over for so long.
But thinks for all your help hovi5, svDaveC, petevtwin650, Baph and oldjack (in order of appearance) Anymore suggestions would be great but I depend souly on this sv for work and what not so I will be bringing it to a mechanic for this one, But I am not afraid to try something that you might think of. |
#23 |
does the SV not have a bank angle sensor ?
#24 |
I guess I am not on the ball with my sensors I don't know about that one. Or where it is located or what it does.
#25 |
Does the 99 model have a tip sensor? I've got a 3 year old pointy and managed to drop it last year, when I picked it up the ignition button would not work, I phoned the garage and they told me to take the tip sensor out (located under the seat attached to the front battery box) and give it a shake as they get stuck.
Ste |
#26 |
i dont think the curvys has................................ ?
#27 | |
when it has been tripped, it needs to be reset. but thats on my honda, not sure if the SV has one. |
#28 |
The SV's don't have a tilt sensor on them.
If the starter relay is clicking, how fast is it clicking? Refer to the previous pictures provided by others for diagnosis there ![]() I suspect your starter might of gone the way of the dodo after all of this, but that's only a guess at the moment. Keep us posted. |
#29 |
Sorry I couldn't be of more help. Wondering if Oldjack was on to something with his loose/corroded connection. Also maybe the battery suffered in the fall too?
As Baph said , please keep us posted Budro |
Faulty start button | Mark_h | SV Talk, Tuning & Tweaking | 10 | 23-03-09 12:17 PM |
show us your belly button | hovis | Photos | 13 | 17-10-08 10:18 PM |
do not press the red button | johnnyuk | Idle Banter | 6 | 26-09-08 03:48 AM |
SV650 Starter Button? | Torn-Thorax | SV Talk, Tuning & Tweaking | 3 | 09-09-06 02:49 PM |
