Old 15-03-07, 09:58 PM   #21
ujoni08
Default Re: manuals
OK thanks. Time to get a feeler gauge and start reading manuals...
Jon.
Old 15-03-07, 11:31 PM   #22
oldie
Default Re: Servicing Valve Clearances...
I just checked mine at 24,000 kms and they were fine. The next time I check them, I will remove the radiator, rather than just loosening it. It will make valve cover removal/replacement much easier and it will be a good time to replace the coolant at the same time.
Old 16-03-07, 09:13 AM   #23
Originally Posted by joeheaven View Post
I just spoke to an SV mechanic in a central London bike shop who said that they have done loads of checks but had never an SV650 that needs adjusting! If they needed adjusting the noise, apparently, would make it obvious. He said they are very solid motors...
Whilst this is true, the SV motor is solid and they don't require much valve adjustment, it would be extremely unwise to ignore the scheduled check.
Written in answer to a previous, related enquiry:
I can understand exactly what you mean, the SV is well known for not requiring much adjustment, but as an unscientific example of how random it can be I've adjusted nothing at all on many 15,000 mile bikes but just recently did one, (that I've known from new, so can be certain of the mileage), at the same 15,000 that needed three shims changing. Another SV, just on 95-100,000 miles now, has had only three valves adjusted in all that time - five have never moved at all, but the 45,000 check on another late last year revealed four needing attention.
Go check.
Good way of doing things. I'd only remove the rad if the coolant was to be changed though, just removing the mounting bolts allows you to move the rad plenty far enough to give good access, particularly if it's subsequently found that no adjustment is needed.
Old 16-03-07, 09:31 AM   #24
timwilky
timwilky's Avatar
For an indication of what a service should cost, i came across this the other day. I am not saying it is what all should charge as obvously overheads/labour rate vaty but use it as an indication. No recommendation made about this dealer. I have never used them nor know anyone who has.
Not Grumpy, opinionated.
Old 16-03-07, 09:35 AM   #25
Baph
Bugger me at the cost of the 600mile service on a K6!!!!
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Valve clearances yorkie_chris SV Talk, Tuning & Tweaking 41 28-09-07 06:46 AM
Valve Clearances - How 'Ard? Biker_Billy SV Talk, Tuning & Tweaking 19 19-06-07 11:04 AM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
