Old 11-06-07, 08:13 PM   #21
weazelz
Default Re: ZX10R shock
change the shock & see if you like it. it's easier to evaluate the difference if you change one thing at once
if you later decide you want more rear ride height - for the reasons Blue says - look for shorter dogbones then
Old 11-06-07, 08:18 PM   #22
Tim in Belgium
Shorter dog bones will also change the leverage on the shock, therefore it is not just ride height and steering geometry that you will alter, not sure if this is good or bad in this case.
Old 11-06-07, 08:20 PM   #23
Blue_SV650S
I suspect the change in linkage ratio the shorter dogbones must make, might aid how it all works together though ... I suppose you could do them individually, but as you have to take the dogbones off to do the shock, its hassle free to put new ones on then ...
Its up to you, its not to hard to retrospectively fit them and as weizely one says, you could do step by step changes ... but I'd just sling them on to start with if it were me (well that is what I did anyway, so I did when it WAS me!! ). Like I said, all works well on the curvy setup
Old 11-06-07, 08:24 PM   #24
Blue_SV650S
Indeed, as it all seems to work well on the curvy, I am making an assumption this might be .. well not crucial, but certainly a large part of the replacement 'package' ... I can't really recommend a curvy 636 conversion WITHOUT the dogbones as I have never tried it ... all I know is it works real well with
I am also assuming the same applies when a GIXER shock is used on a pointy ... but I can't say that for sure obviously...
I wish some pointy owner could come along and confirm or deny these assumptions for a pointy&GIXER
Old 11-06-07, 08:26 PM   #25
weazelz
don't listen to me, I have the front of mine dropped ~10mm, zx10r shock & dogbones
Old 11-06-07, 08:29 PM   #26
Viney
Blimey, Turns a tad quickly then!!!
Old 11-06-07, 08:30 PM   #27
Blue_SV650S
Indeed, for all we know it could be a Kangaroo without the dogbones too*!!
*I seriously doubt that mind, but it is a good idea to raise the rear end anyway as ground clearance is a bit plops as standard if nothing else
Old 12-06-07, 06:17 AM   #28
weazelz
indeed. stock kangaroos being renowned for running wide on corner exit
Old 12-06-07, 07:16 AM   #29
Tim in Belgium
I find the stock Kangaroos tends to hop about a bit at the rear end under any kind of load.
Old 12-06-07, 07:24 AM   #30
weazelz
badoom tish
04/05 ZX10R shock andyb Stuff Wanted 1 17-05-08 07:46 PM
'06 zx10r rear shock weazelz For Sale - SV's and SV related items 0 04-12-06 09:26 PM
zx10r shock weazelz SV Talk, Tuning & Tweaking 10 26-08-06 08:25 AM
ZX10R shock swap red5 SV Talk, Tuning & Tweaking 4 02-07-06 07:05 PM
ZX10R K6 Shock andyaikido For Sale - SV's and SV related items 2 29-05-06 10:49 PM
