Old 25-07-07, 03:26 PM   #21
Baph
Default Re: LED indicator advice
Originally Posted by chazzyb View Post
Call me old fashioned , but incandescant indicator blubs generate light other road users can see!
You're old-fashioned!!
Sure-bright LEDs give out more light (higher Lux) rating, and use less energy than conventional bulbs.
They cost a fair amount though.
Old 25-07-07, 04:07 PM   #22
chazzyb
Do they? When you've stuck a bloody great resistor in the circuit do make it consume as much current as the blub it replaces?
Old 25-07-07, 04:22 PM   #23
Baph
I wouldn't stick a resistor in though, I'd use a flasher relay.
Old 25-07-07, 05:42 PM   #24
Muzzy
Right all sorted.
I ditched the crappy motrax led indicators and got some better qualitly ones with the resisters already in line on eash indicator
Alot easier and took nearly no time at all to do.
The result is a smart brighter rear end
The ill fitting tail tidy i bought is another subject all together though
Old 25-07-07, 05:47 PM   #25
2mths
Call me old fashioned , but incandescant indicator blubs generate light other road users can see! From a 'be seen' POV, I don't go a bundle on LED indies. And another thing , VAG seem to be fitting rear light clusters where the indicator is toally surrounded by stop/tail lights! The red light swamps the indicator light. Maybe it's my eyes...
I see your point. However I think the comparitive result depends greatly on the LED and original units in question though. IMHO and limited experiance LED units can be more directional and this is a negative thing, however within their 'viewable' range they can often be a lot better than the bulbs they replace.
I belive this is one of the reasons that emergency vehicles are fitted with LED units on (at least) the front of the vehicle. Viewing angle is intentionally poor so as not to distract people unnecessarily however within the intended viewable range F! me are they bright. Was messing around with a new St. Johns Ambulance a few years ago and in bright sunlight the result was very impressive.
Totally with you on the VAG thing. I think the Golf is the biggest offender I've noted, but I'm sure there are others.
Old 26-07-07, 10:14 AM   #26
Stu
Trinity
Stu's Avatar
i sorted my bike out by flogging the aftermarket indys on ebay and putting my OE one back on
I might be with you on that one.
But I love the cars that get LED lights right like 3 series BMW, Aston Martin DB9. Range Rovers are like VAG, but I think it works on them
It's so crisp & clean how they are either on or off, no fading off & heating up.
Oh, and the front LEDs on Audis & Porches, bring it on they're so cool!
Old 26-07-07, 10:33 AM   #27
i like the angle eye's lights on the beemers. led's are great but i'm not one for enjoying having problems, i always looks for the easy way out.
Old 26-07-07, 11:38 PM   #28
toonyank
LED's generate visible light as well. "Light Emitting Diode" and mine are as bright as bulbs and work a treat. If they weren't bright enough, they wouldn't be legal.
They're just very low impedance so they require a resistor in parallel to mimic a bulbs resistance to lower the flash rate that's what this whole thread is about.
Old 13-04-08, 09:34 AM   #29
Biker Biker
It seems that most people have had a problem with fitting Motrax LEDs with motrax universal relay... err me to. I have search thew forum and done as instructed....
Old 13-04-08, 09:34 AM   #30
Biker Biker
However the lights remain lit solid... what do I need to do next?????
Please help
indicator advice dave1701 SV Talk, Tuning & Tweaking 2 11-05-08 09:24 PM
Indicator Q Davido Bikes - Talk & Issues 9 16-01-07 09:43 PM
indicator? kwak zzr Stuff Wanted 3 03-12-06 09:26 AM
WTD: Bar End and Fat OEM Indicator Freeloader Stuff Wanted 3 25-02-06 08:44 PM
Indicator / belly pan advice please! Carl SV Talk, Tuning & Tweaking 6 01-01-06 06:02 PM
