Old 27-03-10, 05:20 PM   #321
barwel1992
Default Re: rear shock change
^ haha my mum would kill me
Old 29-03-10, 01:39 AM   #322
barwel1992
any one know if i up the spring rate on my gsxr1000 k3 rear shock, will i need to change the valving ? thinking about 9kg spring or a 9.5kg
Old 29-03-10, 09:32 AM   #323
Yeah if you wanted the same balance in the shock, but if you're valving and springing it then it would make more sense to start with a shock with closer to the length you want.
Old 29-03-10, 10:34 AM   #324
barwel1992
^ ok cheers YC, will leave it as it is then
according to racetech i need a 9kg spring but the standard is 8.6kg so most likely wouldent have been worth it any way
Old 29-03-10, 10:42 AM   #325
Racetech is not the best, they just use a table, a tuners guess is more reliable.
If you did go that route then you would be better to use a longer shock so you could get rid of your raising dogbones. But many people think there aren't any OEM shocks worth revalving.
Find a secondhand penkse
Old 29-03-10, 10:45 AM   #326
barwel1992
how did i know that was coming
well if i decide to keep the bike for a long time i might invest in one but not at the moment
Old 29-03-10, 10:47 AM   #327
They are that good. Same step up from GSXR shock or whatever other OEM kit to the penske as you get going from the stock SV one to a GSXR one.
Old 29-03-10, 10:59 AM   #328
barwel1992
cool they do sound good, just cant justify the cost of one at the moment
Old 30-03-10, 10:38 PM   #329
barwel1992
whats the correct sag for a gsxr 1000 03 shock on a pointy ? also while im at it what the correct sag for the front end
Old 12-06-10, 04:39 PM   #330
Nobbylad
Nobbylad's Avatar
Finally installed my K3 Gixer rear shock onto the pointy. What a palava! The battery box is integrated with the undertray etc so all the rear plastics had to come off. I struggled a bit with getting the bike off the floor, but axle stands under the pillion pegs did the job. Battery box has been trimmed etc and I'll need to get a smaller profile battery (think Neeja got one didn't he?).
Problem is, I don't have a torque wrench suitable for doing up the bolts (the range on the one I have is too high). Quick question though, the bolt at the top of the shock, should that be tightened so much that the shock doesn't move, or is the shock supposed to pivot on this point?
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
