#31 | |
![]() But of course, sometimes you want the fork to react faster- if you load it up the same by riding over a rock you want it to get out of the way. So here your treacle would be a complete sod, the event it's reacting to is over long before it can fully react and you end up with the whole bike kicking. Again, impairs your grip, just as an overstiff fork would. So you want a fork that's resistant to braking dive but pliant to impact. And then of course, you've got the rebound damping, which is what Blue was talking about earlier- with the SV forks the damping both ways is controlled by the oil, change the oil alone and you increase both compression and rebound damping, so the fork returns slower. And then you get what I've always called packing, but what blue calls pump-down, the next event happens before the bike's recovered from the last, and it ties itself in knots. Get that on the rear, and you have the best recipe for a tankslapper. Get it on the front and you have a huge loss of grip among other things. It's bad news. Increase the spring rate though, and the increased damping is offset against the fact that the fork pushes back harder. But... All about finding a balance. If the stock oil wasn't underdamping the front as standard- and personally I think it is- it certainly is once it's been in there for 10000 miles. And as Embee said, not all fork oil is equal, 2 different 10Ws may act totally differently. I think we put Bel-ray in one, and Silolene in another, and you really could feel the difference. I reckon you can increase the damping enough to make a difference without causing severe problems, though. If you go nuts and fire in 20W or even 15W, expect problems, but a fairly viscose 10W or a light 12.5W could work out well. That said, springs are only £70, that's less than most cosmetic mods and it makes the bike work. It's not a mod, it's a correction, it's just like buying shoes the right size. This message is too big, I'll make another ![]()
#32 |
So, emulators. They're ace. I pretty much agree with every word Blue said up there. Fairly simple, not externally visible, quite effective. The only sort of cavea I'd put on it is that I did my entire GSXR front end swap for less than a set of springs and emulators, and if you're the right weight for the stock GSXR parts there's no comparison there, you don't have to be fast to benefit either (as anyone who's seen me ride knows!) If you're heavier, you have to chuck money at GSXR forks to get them to work right for you too, for a big'un emulators and springs set up right is better than a true cartridge fork with totally soft springs.
But, first things first, springs and oil is pretty cheap, it's very effective, it's simple to do, and if you do decide to upgrade to emulators afterwards you don't lose a penny as the springs will still work. I'm not going to say it's essential, but it's a shame to have a £4000 bike not working properly for the sake of £100 worth of parts.
#33 |
I've learnt more about compression damping reading this thread than I have in reading magazines and MCN for the past 11 years.
So, next...rebound damping! Matt |
#34 |
Rebound has been touched on above, but in a nutshell, rebound damping is there to control the rate of the springs return – you imagine a spring fully squashed then suddenly let go … PING!!!!!
![]() ![]() ![]() There will be tones of stuff on the net about this if you are interested. This website is referenced quite often on here, a good read should answer your above question (and then some). ![]() Give it a read and if you need anything clarifying further, then post it here and I am sure the .org collective intelligence should be able to help ![]() Oh and northy, yep, agree if the oil is not the correct weight to start with then changing would benefit things!! ![]() I was just pointing out that if you are 18st, your forks problem is not best solved buy running stock springs, but with ‘crude’ oil to stiffen!!! ![]() Last edited by Blue_SV650S; 14-12-07 at 03:27 PM. |
#35 |
Oh yea, gotcha there blue. I've never thought about suspension and springs before and stuff, i know its all there and what it does but never the full dynamics, hence why im only just learning now.
You guys should teach! Matt |
#36 |
Oh and a good way to 'stiffen' the front end, but yet retain initial compliance is to reduce the 'air gap'…
Think of the forks as a sealed unit, after setting the stock oil level, there is some air in there between the top of the oil and the cap. When the forks are compressed, the area inside the forks is effectively reduced!! Therefore this bit of air is also compressed, and compressed air acts a bit like a spring!! – i.e. it wants to return to its former state and therefore provides a force!! ![]() Reduce the initial amount of air, keep the same travel, that air gets is compressed more, it therefore has a greater return force ![]() What is also cool about using air gap is that it is ‘progressive’ you can have nice softer springs that won’t be allowed to ‘bottom out’ as near the end of the stroke the air compressions contribution is significant enough to help out!! ![]() Before everyone goes filling their forks to the top … ![]() ![]() ![]() ![]() |
#37 | |
![]() It all sounds a bit academic to some, but I know at least one guy on this forum who's crashed because of a bad shock setup (far too much preload, right hander with a heavy camber and a ripple in the tarmac, wheel skimmed across the surface and chucked him into a ditch. Again, naming no names)
#38 | |
#39 | ||
![]() ![]() Quote:
![]() ![]() Being able to ride the bike 'feel' what is going on and then make educated adjustment has to be the way forward?? Suspension is a black art, but the SVs simplicity and lack of adjustment actually makes the job of tuning your suspension to your needs so much easier ... ![]() Last edited by Blue_SV650S; 14-12-07 at 09:01 PM. |
#40 | |
you can get same with selecting correct spring.or lengthening travel buy getting rid of hydraulic lock piece. |
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. | sv_rider1990 | SV Talk, Tuning & Tweaking | 12 | 11-07-08 05:15 PM |
preload adjusters. | scottjames | SV Talk, Tuning & Tweaking | 16 | 28-04-08 04:06 PM |
Fork preload adjusters on a curvy? | Berlin | SV Talk, Tuning & Tweaking | 12 | 06-09-07 08:00 AM |
K4 fork spares, damper tubes,preload adjusters,fork lowers | ianofbhills | For Sale - SV's and SV related items | 11 | 13-03-06 06:58 PM |
FORK PRE-LOAD ADJUSTERS ON A 'NAKED' | alexb | SV Talk, Tuning & Tweaking | 4 | 21-01-05 09:19 PM |
