Old 06-01-09, 04:41 PM   #31
philbut
Default Re: Abba (stands).....
Originally Posted by Ceri JC View Post
Have you considered one of these?
http://www.abbastands.co.uk/product_details.asp?id=2
I've not used one, but it looks expensive for what it is. For the same money you could get one of these (managed to get it a bit cheaper IIRC), which I have:
https://sslsecurity.co.uk/Aandrracin...D=277&CatID=84
More stable than the ABBA front lift looks and can be used with just a rear paddock stand (rather than ABBA). Only downside is as it goes through the headstock it might get in the way/prevent some jobs, but for 90%+ of front end work it's great. The other 10% is so infrequent that I'll just use the old "block of wood and car jack" bodge when the situation arises.
I just use a trolley jack under the manifold or if I'm not removing the forks, I use my rear paddock stand (don't own a front one) together with the axle removal lugs to raise the front wheel - 10 second job.
I really rate the ABBA stand too, although the adaptors aren't cheap. I now make my own.
Old 07-01-09, 07:05 PM   #32
hob
Originally Posted by Tiger 55 View Post
You're doing it wrong!
It appears I may have the mounting kit the wrong way around
That'll teach me for not reading the instructions
Abba Stands-not the normal question. arcdef Hardware 21 08-03-09 04:30 PM
nws stands no longer available? aarond Bikes - Talk & Issues 20 03-12-08 10:00 AM
Paddock stands, so many which ones are best? krhall Bikes - Talk & Issues 13 24-04-08 04:39 PM
Bike Stands 600+ Bikes - Talk & Issues 23 06-03-08 04:07 PM
NWS/Abba "swingarm" type stands tomjones2 Bikes - Talk & Issues 1 12-11-07 01:17 PM
