Old 11-09-09, 09:38 AM   #31
LK-SV
Default Re: Preload settings .... again !!!
if you've standard springs fitted, max on the front, one click off max on the rear.
Cheers Mark.
Changed this before riding home last night .... did the trick perfectly ..... front end in particular feels much better !!
Never before have I felt so 'over-weight' whilst being less than 12 stone !!
Old 21-09-09, 11:30 AM   #32
madness
Default Re: Preload settings... yet again.
Right, for all you people who believe that adusting the preload doesn't affect the way a bike handles, click on this link and read the section on preload!
http://books.google.co.uk/books?id=r...reload&f=false
Old 21-09-09, 12:20 PM   #33
custard
fzzzzzzzzzzzzzt!
do you have a copy of that book in english?
Old 21-09-09, 01:02 PM   #34
madness
Originally Posted by custard View Post
fzzzzzzzzzzzzzt!
It's a bit like being back in physics class all over again!
Old 21-09-09, 01:44 PM   #35
custard
dunno bout that, i actually want to understand this
Old 21-09-09, 01:53 PM   #36
ophic
ophic's Avatar
I read it. It cleared up a few bits and pieces. It will affect ride height, and therefore steering geometry. It will affect where your suspension limits are - ie where it bottoms out or tops out. It won't affect anything else. On linear springs, it doesn't make anything stiffer or softer. It doesn't change the amount or rate of spring deformation occuring if you go over a bump, assuming it hasn't hit the stops.
Silver SV650SK3, Fuel exhaust
Old 21-09-09, 08:00 PM   #37
madness
Interesting point is that adding preload lowers the amount that a fork can extend to follow irregularities in the road. So, if the tyre can't follow the irregularities it must be losing contact with the road, not a good situation.
Old 21-09-09, 08:03 PM   #38
This is why you need some sag, but not too much
Old 21-09-09, 08:14 PM   #39
madness
What I can't understand is that when I increase my fork preload to achieve 35mm of sag, the front end felt like it was skipping about over bumps/irregularities. Not good when the bikes mid corner.
Old 22-09-09, 08:10 AM   #40
ophic
ophic's Avatar
The whole point of preload is to get the bike to sit in the middle* of its suspension travel. Generally with no preload it would be sat too low, therefore having loads of extension but very little room for compression. Remember irregularities go up as well as down.
* I realise the optimum point isn't exactly the middle
Sag and preload etc AndyBrad SV Talk, Tuning & Tweaking 12 20-06-09 06:59 PM
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. sv_rider1990 SV Talk, Tuning & Tweaking 12 11-07-08 05:15 PM
Preload Settings Giffer2 SV Talk, Tuning & Tweaking 5 11-08-07 04:25 PM
fork preload steveg SV Talk, Tuning & Tweaking 3 08-03-06 07:33 AM
Suspension preload for 2 up STRIKER SV Talk, Tuning & Tweaking 0 22-02-06 06:46 AM
