Old 07-10-09, 04:44 PM   #31
Dave20046
Dave20046's Avatar
Default Re: Oops..
Originally Posted by Spikenipple View Post
Yup a genuine Suzuki lever from the parts counter at your local dealer is just over £50.
That's insane
Old 07-10-09, 04:52 PM   #32
xXBADGERXx
Default Re: Oops..
James , the Fixer-Peg was posted today first class , It didn`t have the correct bolt with it so I threw in a 6mm cap head Stainless bolt with Stainless washer for you . I suspect it will foul the gear selector rod so you may have to go and buy a button headed Allen bolt to clear it . I filed my broken gear peg flat , then drilled a pilot hole in the centre of the gear lever after centre punching it then drilled a 6mm clearance hole to allow the bolt to pass through . Hope this helps and saves you some money feller .
Old 07-10-09, 05:04 PM   #33
TheOnlyNemesis
Default Re: Oops..
glad to hear your ok, you can join me in not riding for a while now, haha. good to see the bike isn't too badly damaged, gets costly quite quickly otherwise.
Old 07-10-09, 05:35 PM   #34
metalmonkey
Default Re: Oops..
I had a near miss with a red van today, as he didn't bother to stop at a roundabout, only to find yours truely mid roundabout on my Litespeed. Now I know I'm fast, but not that fast and I was wearing a bright red cycling top, so he couldn't say he hadn't seen me.
But his observation on the approach alerted my 6th sense and I knew he wasn't going to stop, so I slowed down. Lucky me
Yes I had a moment with a van on Monday, with the guy on the phone! I pointed out his error, he was very applogetic by the time I finshed talking.
James bad luck about your off, I rode home in the rain tonight which wasn't soo nice hopefully all the roads should be a bit cleaner now? (is that possiable)
Try SV spares for the bits you need, they may have them in. I'll find a link for ya. Take it easy dude
Old 07-10-09, 06:00 PM   #35
Icanopit
Default Re: Oops..
James? I am only in Hartshill, IF I can help in any way give us a shout, tools/tea/coffee even a £1 out of the till? available 24/7 and retired.
JOHN
Old 07-10-09, 06:12 PM   #36
jamesterror
jamesterror's Avatar
Default Re: Oops..
Thanks for replies everyone, yeh I got off very lucky I'd say.
Cheers mate When it arrives I'll try and sus it out from your instructions and if I fail I'll drop you a PM.
JOHN
Thanks, I'll drop you a PM if I get stuck or anything, I believe at the mo its just cosmetics as I've listed above, as well as the side stand is slightly damaged.
jamesterror is offline   Reply With Quote
Old 07-10-09, 08:07 PM   #37
metalmonkey
Default Re: Oops..
As promised;
http://www.svspares.com/
Hope that helps dude
Old 07-10-09, 08:37 PM   #38
jamesterror
Default Re: Oops..
Originally Posted by metalmonkey View Post
As promised;
Star, cheers mate
Old 08-10-09, 12:04 PM   #39
jamesterror
Default Re: Oops..
Thanks Badger, I was going to wait till the weekend to fit it.. but I've just done it and is on all good
Thanks again!
Old 08-10-09, 12:52 PM   #40
jamesterror
Default Re: Oops..
I'll keep this thread updated to my progress of getting bike sorted... Its ridable again thanks to badger as I can change gear!
Oops Jayneflakes Idle Banter 13 11-06-09 02:47 PM
Oops Stu Soho Massive 19 03-03-09 06:34 PM
Oops! Berlin Pennine Massive 8 11-12-08 11:34 AM
oops weazelz Photos 14 23-03-07 11:08 PM
oops Quiff Wichard Idle Banter 1 30-07-06 12:19 PM
