#31 | |
#32 | |
vi used properly is a VERY powerful tool, comparing it to notepad is like comparing Rossi's race bike with tractor. Just because you cant be bothered to learn it properly, dont blame the tool if you cant use it. As for your suggestion, thats fine, unless of course the program you are re-writing the file, doesn't like Windows/DOS style line-feeds...
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#33 | |
Silver SV650SK3, Fuel exhaust |
#34 |
Ah young man, the folly of youth.
What happens when you are presented with a locked down system, only you and a console. If you need to make changes, learn to use the tools that will always be available. Of course people have their own workrounds. that is the beauty of linux, if you don't like a command name, give it an alias, if it doesn't do what you want, write it yourself or steal somebody elses. I used to alias VMS type commands to their unix equivalent. Then over time I reversed and built command procedures/symbols etc to emulate unix commands under VMS etc. But, when somebody has bodged a config file and you have to boot single user mode or off a cd etc you need to know the base tools
Not Grumpy, opinionated. |
#35 |
i get round that by using a app called text-pad it allows to save as unix file format apparently.
I don't dissagree that vi is powerfull but there are far easier options out there now with syntax highlighting and debuging assistance. the guys i work with use sql+ i use Toad or pl/sql editor it's just easier to read and has more functionality. when i was in college the tutors asked us to use notepad to do html i said no and used a editor that hilighted the html. i don't understand why use somthing that is clearly more difficult to use. I'm a mechanic to trade and for me using a bog standard screw driver to get out a tight screw out instead of getting the snap-on one is like chalk and cheese. why make it harder. |
#36 |
Which screwdriver you calling vi then, cus its more like the snap-on on to me.
#37 | |
Good code should run on the command line without me having to remove extra lines, spaces etc. Lazy developers are the biggest thorn in my side. If they insist on devloping in Toad or SQL Developer, then they should at least test to ensure it runs on the command line and fix it if not.
- K9 SV650S: Hel brake lines, carbon end can - SZR660: The project... - K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now) |
#38 |
#39 |
well i don't have to ask for my stuff to be deployed. so no concerns for me. those blasted devs!!
#40 |
Yes, I use IDEs for my development, far too many
Visual Studio Eclipse Oracle Jdeveloper etc. I also use a 10 year old windows editor because it can display in hex/ascii etc and most important for me cut/paste in columns and not just lines. Horses for courses. of course the specialist tools make life easier, that is why somebody invented them. However, you also need to be able to work from base principles. So all you have available is a CLI :- a dumb terminal or putty shell. You have no fancy tools. I have managed unix boxes in china across 64K vsat links. even an X session is a non starter. it is cli or nothing. still no point in arguing. Those who need to be able to do the job, know their tools. Those that don't, dont get the job
Not Grumpy, opinionated. Last edited by timwilky; 02-02-10 at 01:41 PM. |
A few from London. | RobH13 | Photos | 9 | 16-01-10 11:34 PM |
Anyone want to join me on a trip to London...from London? | Kinvig | Idle Banter | 13 | 18-11-07 10:09 PM |
Going UNIX | Scooby Drew | Idle Banter | 21 | 07-10-06 10:31 AM |
Unix Sysdamin wanted | PBx | Idle Banter | 1 | 20-04-06 11:42 AM |
What to see in London? | greshaki | Soho Massive | 6 | 30-03-06 04:42 PM |
