Old 05-05-05, 05:34 PM   #31
chewy22
Originally Posted by cb9002
Burner, you've got it wrong!
The combustion process doesn't fully complete in the engine itself, the PAIR injects more air (and hence oxygen) into the can so the unburnt fuel burns while its still hot enough to do so.
Once the exhaust gases have left the can, they cool too quickly for further combustion to take place. This is why exhaust emissions ARE reduced (not just diluted) with the device.
Just to bring this subject back to life. The catalytic converters are fitted into the end cans on the new range of SVs I now suspect that if this process was removed using the original can (NOT what I am recomending here) then the un-burnt gasses will bugger up the cat in time. But most people will in the end replace there end cans because 1 Its Cheaper than an original 2 bike looks and sounds better. The drawback is this system (PAIR) will cause the popping and backfires with aftermarket cans. Very much more on the 1000 more than enough to blow the rubber mounts where the throttle bodies that join the air box.
Old 26-06-10, 07:22 PM   #32
Razor
Default Re: PAIR REMOVAL MODIFACATION
has anybody done the pair mod to their bike?
i have a baffled road legal can and don't have any kind of popping or banging on the over run... i wouldn't mind some like...
Old 26-06-10, 07:33 PM   #33
Holdup
A whaaa, take the baffle out and mine usualy pops around 4k rpm in 3rd gear
Pair system lawson17 Mini-Twins 7 10-01-15 09:47 PM
Total Pair Removal Kit Bibio SV Talk, Tuning & Tweaking 9 08-05-11 10:29 PM
Brand new pair of tyres for sv650 Skin For Sale - Other Bikes and General biking items 2 22-07-09 01:01 AM
Datatool System 3 removal. Lozzo SV Talk, Tuning & Tweaking 17 14-05-07 09:42 PM
Pair system chewy22 SV Talk, Tuning & Tweaking 13 18-11-04 04:46 PM
