Old 04-06-05, 03:01 PM   #31
instigator
Back onto the original topic Go riding along, about 5k or 6k, then let go of tyhe throttle so the engine starts its usual braking business. Flick the kill switch to off then back to on after a second or two (or five ) Cue the bang and you'll carry on your way
I've never done it with the clutch in and have never done it with the throttle open either, just under engine braking, which I am led to believe is the easiest way to do it
Old 06-06-05, 11:15 PM   #32
sd1cko
Or you could join the 'REVZ' reading boy racers and buy a kit, which works on both FI and Carbs, which basically consists of a small spark plug put into a drilled hole in the end of yer exhaust and wired to a button (which also invokes the kill switch). This also then produces big FLAMES when using full throttle Fast N Furious Style. Can be bought for both bikes and cars for about a hundred notes.
Dont think ill be sad enough to bother me thinks (maybe when i was 18 i would have )
Old 06-06-05, 11:32 PM   #33
Warren
my mate has one - got nicked for it too.
he paid 10 quid for the kit.
my other mate has made one - cost about 2 quid in parts.
i wouldnt like to be using one if it all goes terribly wrong and blows me up.
Old 07-06-05, 12:38 AM   #34
wheelnut
the ingredients for a successful backfire are about 7000 revs a small boy walking down the road with his grandad and hit the kill switch :P i didnt pull the clutch in, i didnt do anything except hit the switch momentarily
The look on his face was amazing I know, I deserve an ASBO, its just I could see in that little lads face, he was going to grow up to be a hooligan too
It is not big and its not clever!
Well it is actually :P
Old 07-06-05, 07:37 AM   #35
Sholay
I have destroyed a can doing this (a very long timeago).
The principle is pumping unburnt petrol through into the exaust system which then ignites when you turn the engine back on. When you start exploding petrol/air mixture in a space not designed for it, then problems can arise.
Old 07-06-05, 09:16 AM   #36
wheelnut
but when your grandad use to run a Morris Oxford or Austin Cambridge, he had to decoke it every 6000 miles :P
The SV is already fitted with an automatic decoke device
OK, I know.
Its probably a stupid thing to do, but so is riding a motorcycle at 120 mph
Old 07-06-05, 09:25 AM   #37
Biker Biggles
Biker Biggles's Avatar
Small boy with his grandad under a railway bridge is best
Old 07-06-05, 09:47 AM   #38
BernardBikerchick
heeheeee you all make me chuckle !!! happened to me in derbs, nearly kacked meself ! been wantin to do it for ages, all this good advice might give it a go !!
Old 07-06-05, 10:05 AM   #39
SV650Racer
i suppose people who use kill switches to produce a bang wonder why bikers are often seen in a bad light by non biking people..does make you wonder!.
IMHO its a pretty chav thing to do..why?????????
If you have a carbed bike it can do alsorts of horrid things to your bike, even as far as setting your can alight and blowing the carbs off, to damaging valves and spiking the ignition..
TBH you will have more street cred if you learn to ride your bike quicker and better rather than acting a fool...
for me it gets put into the same catagory as those that have clio's with neon lights
Old 07-06-05, 10:06 AM   #40
Cloggsy
Ditto
Consumer goods and fit for purpose... amnesia Idle Banter 8 06-05-09 08:36 PM
backfire! vardypeeps SV Talk, Tuning & Tweaking 7 21-08-08 12:01 PM
dual purpose tire for SV650 standard tguidry SV Talk, Tuning & Tweaking 1 14-10-07 05:40 PM
The purpose of a forum? toonyank Idle Banter 38 03-08-07 02:07 PM
SV650S - Not fit for the purpose. Tiger 55 SV Talk, Tuning & Tweaking 80 14-02-07 12:14 PM
