Old 11-03-06, 12:04 PM   #31
Professor
Originally Posted by petevtwin650
With a ramp the guy should have been able to do it himself anyway.
Hope this isn't an indication of Highways abilities.
Can someone tell me what is Highways?
Old 11-03-06, 12:29 PM   #32
fizzwheel
fizzwheel's Avatar
Default Re: re
Originally Posted by steveg
Got bike back today , dropped back by mechanic who showed me duff plug that he had taken out , ( he has replaced both btw) , seemed a nice bloke.
Asked if it was a problem with damp getting into front plug , but said no it was dry just a duff plug .
Spoke to Cust service bloke who appoligised asked him to supply & fit fender extender as a good will gesture which he has agreed to do when I get 600 mile service next weekend .
Hopefully thats it sorted
Cheers Steve
Good result, glad you got your bike back
Prof "Highways" is the same of the dealer that Steve has been using
Old 11-03-06, 08:26 PM   #33
Anonymous
Default Re: re
Problem was that one of the plugs had gone down & was only running on 1 cyclinder...............
.........I have since heard of another 2 plug fails on new SV 's maybe a duff batch of plugs?
Err....just a little warning note: one plug "failing": possible. A whole batch....very, very unlikely (although not unheard of). The problem is that when some (stress, SOME) mechanics replace a spark plug, and the problem then goes, they report a "duff" spark plug. Unfortunately, they then rarely search out the cause of why the plug "failed" - or probably more accurately, fouled.
The MOST common causes of this are: engine run very slowly for extended periods (not uncommon during run-in); too much fuel (perhaps caused by use of choke and enthusiastic throttle pumping); insufficient available voltage to put a spark across the plug gap (sometimes a faulty ignition system, most commonly the plug shorted out by water around the leads,caps etc etc).
What this all means is that it MIGHT just hapen again if they haven't fixed the cause. You might consider, if you do a lot of short journies at rather slow speeds, a switch to Iridium plugs. They are more tolerant.
Old 11-03-06, 09:27 PM   #34
steveg
steveg's Avatar
Default re
Mechanic showed me plug that had failed it was not fouled , if there is still a problem then I will be straight on the phone back to the dealer .
Bike is used daily for 50 mile run , not much town work therefore average normally 60 - 70 mph , bike not left to idle at startup
Will have to wait and see hopefully it was a duff plug , but hay who knows except the mechanic who seemed ok to me
Guess will see
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 11-03-06, 09:31 PM   #35
Blue_SV650S
Guess the only thing left to do is to fire it up, get on it and rag the nuts off it to ‘learn it’ good!!! After this it will be to scared to misbehave again
Old 11-03-06, 09:36 PM   #36
steveg
steveg's Avatar
Default re
You're damn right!
AKA Papa Smurf
Old 11-03-06, 10:35 PM   #37
Default Re: re
yes ive had this where the mec firstly changes the plugs and if the prob seems to go away then he thinks its sorted. trouble is with me and my zzr the prob came back.
Getting bike back for a few days FG1 SV Talk, Tuning & Tweaking 10 05-12-08 07:02 PM
So a few days off, will you be out on your bike? Defender Idle Banter 11 21-03-08 12:05 AM
Arsety **** **** Carsick Idle Banter 8 15-08-06 04:04 PM
Boooo no bike for me for a few days Daimo Idle Banter 7 08-07-06 03:19 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
