#31 |
Thanks a lot guys.
there is some good help there. last night i had a good look. there are NO LEAKS ![]() looking at the resevoir, there is no level of fluid. open it up, i jus see a black lining, i topped this up (a little too much actually ![]() brakes are all good, obviously the new pads need bedding, but it seems ok. i might like a more solid lever, but i bled the system.... so that must be how it is ![]() the issue now is.... i cant see the level on the resevoir ![]() i should be able to see the fluid level through the plastic.... right???? |
#32 |
wooaaaahhhh there horsey
the black thing needs to come out too, then put the fluid in, it's the black thing that gies you your seal afterwards |
#33 | |
#34 |
The Sick Man
Many people dont know what the black thing is, surprising.
As Viney said, top up fluid to correct level then put it back in and push it down till all the air is out of the resovoir.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#35 |
ive just read the how-to at the link above...
thats a very useful webpage! i read the how-to on changing front pads, as i jus did it using common sense..... i was quite shocked at the bit about removing a metal clip and attaching to the new pads ![]() ![]() ![]() ![]() Im worried now!!! i never did this, but im sure the pads that came out were the same as the pads that went in.... so, could the clip have been helf in the caliper on both sides??? what does it actaully do??? |
#36 |
it's an anti squeal shim. Not strictly necessary.
#37 |
oops
![]() i bet some people are quite shocked im working on my own brakes ![]() ok... im sure the shim is in the caliper, cos i coppered it up with the back of the pad. as for the black bit in the resevoir.... well, no excuse there, i did wonder though ![]() i'll sort it out. Thankyou very much ![]() |
#38 |
if you want firmer feel in the lever (ie less freeplay)
you can use the adjuster on top of the lever. 1 being the strongest i believe. |
#39 |
Going back to the DOT 5 issue - don't use it!
The usual stuff is DOT 4 and is good enough. BUT it absorbs water and goes off with time - hence the need to replace it. DOT 5 does not absorb water and does not go off BIG BUT water then collects in the lowest part of the system - ie the caliper - this causes not only corrosion, but also has a tendency to boil if you brake REALLY hard - that then introduces a compressible gas in your system and your brakes fail DOT 5.1 gets round the problem associated with DOT 5 and is just like DOT 4 but operates at a higher temperature. You will not get an SV to a high enough performance to require the increased temperature resistance. (Besides DOT 5.1 is really expensive by comparison) So, DOT 4 is OK for the vast majority of road bikes, DOT 5 tends to be used by rich race teams who can afford to replace their fluid every weekend, DOT 5.1 tends to be used by high performance bikes. |
#40 | |
Where the hell am I?
Obviously that all depends how long your fingers/hands are. If you got spongey brakes that aint gonna make any diffrence to the spongy-ness
. "Computers are great! Not for communicating tho. They have one fundamental flaw ... they don't have eyebrows." AlpineCarStereo: you win ....... eeerrr ..... ummm ..... my undying support of you, the greatest Mod this forum has ever known. My Leige. davepreston: ![]() |
Brake Bleed nipple/Mityvac/Brake Fluid query | Ceri JC | SV Talk, Tuning & Tweaking | 15 | 20-01-09 02:04 PM |
Dot 5.1 brake fluid | DanF | SV Talk, Tuning & Tweaking | 2 | 09-04-07 03:15 PM |
Brake Fluid top up | Nekkid | SV Talk, Tuning & Tweaking | 7 | 30-03-07 11:57 AM |
Do I really need to change my fluid. | dmracing | SV Talk, Tuning & Tweaking | 18 | 30-10-06 01:33 PM |
Need a quick way to change cooling fluid | Dennis | SV Talk, Tuning & Tweaking | 4 | 23-05-06 01:23 PM |
