#31 |
Is it not
#32 |
Ok, quick pic of the axle should let you see the distance it's protruding (big word for today
![]() Re. the pad types, the set North sent were indeed EBC FA229. The set I bought (for right side, as pictured) were Armstrong GG coded PAD320221 - but they have a "cross reference" for EBC's coded FA231 (a little concerned as this isn't the same code as North's set). FWIW, the pistons aren't retracting fully but it's not the pads that are scraping the disc, it's lug #1 on the caliper - as lug #2 isn't touching though (which is on the same plane) this would kinda back up Sid/TSM's theory of the forks. ![]() |
#33 | |
The Sick Man
The axle bolt should sit flush with the side of the leg, which its not on yours. Have to checked to see if its fully threaded into the other fork? If it was not the wheel would have some sideways movement so its unlikley as you would tell this easly.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#34 |
Don't worry, 229 is left and 231 is right! (at last, I contribute something acccurate to this thread!)
#35 | |
The Sick Man
#36 |
God damn you TSM!
#37 |
ROFL
![]() TSM, could you define "fully threaded into the other fork" - I mean, it's in there but obviously can't be enough if it's still sticking out the other end. The problem is (as I mentioned) was I think it was torqued to the right level when put on. |
#38 | |
The Sick Man
Has the bike ever been involved in a crash on either side, by you or any other owner that you are aware? If you are not aware then you can check, look on the headstock and find where the steering stop is, put your finger over each side and it may feal like its indented a little bit.
#39 |
Will need to check that tomorrow now - when you say "steering stop" do you just mean where it's on full lock to either side?
Sorry for all the questions ![]() |
#40 | |
The Sick Man
Brake light probs | Baz | SV Talk, Tuning & Tweaking | 9 | 24-09-08 08:07 AM |
reg rec probs maybe | dizzyblonde | SV Talk, Tuning & Tweaking | 4 | 27-09-07 04:07 PM |
more probs | hovis | Idle Banter | 6 | 02-10-06 09:05 AM |
Front brake probs, advice needed. | Dirty Baz | SV Talk, Tuning & Tweaking | 14 | 21-03-05 04:18 PM |
sticking brake pt 2 (got some lovely pictures ) *update* | Warren | SV Talk, Tuning & Tweaking | 18 | 24-01-05 04:59 PM |
