Old 27-05-07, 12:27 PM   #31
Blue_SV650S
Default Re: How do I work out theoretical rear wheel revolutions?
how cool is that, is that in visual basic? - i've been getting to grips with the basics (no pun intended) but kind of hit a wall when i couldn't think of anything useful to apply it to...
have you seen this:
http://blogs.msdn.com/coding4fun/arc...8/1709215.aspx
Yeah VB, like you I needed an excuse to play!! I could 'polish' it more or add cool graphing gizzits, but it does all it needs to as it is ... oh and in my calculator, if you click the 'page' icon on the tool-bar, you can make another child window allowing you to have 2 (or more) configurations side by side
I confess I didn't read the whole article, but I got the gist and yeah, looks cool!
Old 27-05-07, 05:29 PM   #32
rear tyre is 17 inches in diameter
Wheel is 17", tyre is a bit more
Old 27-05-07, 05:31 PM   #33
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
lol, i'm not 100% certain but i think we might have covered that one
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 27-05-07, 06:02 PM   #34
Ah, look, there's more than one page! Who would have thought it
Anyhoo. If it's any use, I just fired up my Veypor for a moment, and my old 160 rear roadtec had a circumference of 1.86 metres apparently- and I measured that with string, so it must be right
Old 27-05-07, 08:59 PM   #35
stuartyboy
Old 27-05-07, 09:32 PM   #36
the_lone_wolf
Captain Awesome
Originally Posted by stuartyboy View Post
An honours degree in Electronic Engineering with Maths & Semiconductor Physics actually! Several years teaching physics and employed as a process engineer - which believe it or not involves physics and maths.
i have an honours degree in physics, what do i win?
The "formulae" are equations actually
incorrect again, seeing as how we're going for semantics i'll elaborate for your convenience...
an equation is simply 2 expressions that are equal, for example: 2 * 4.5 = 3a
in all cases this could also be called a formula, in fact the only time a formula cannot be an equation is as thus; the formula 3x > 2y could not be called an equation, because the two sides do not equate, one is greater than the other
quoted from a ducati 2003 749 performance manual. You'll be telling us Ducati are wrong next. I don't need to prove anything mate.
i'm sure ducati are very good at producing equations for ducatis - the formula you quote completely fails to take into account that the primary and final gear reductions will be different on an SV than a ducati
if you want to remain at all credible i'd say you do have something to prove, i've pretty much shown your formulae to be completely meaningless by doing something as simple as applying numbers from a real world situation to give a ludicrously disproportionate answer
show me how you can make 2nd gear, with a ratio of 1.777, 30mph, 5000rpm at the engine and a total wheel diameter of 0.624m fit into this formula:
rpm = (mph x gear ratio x 336) / diameter
i would bet you can't, and that's why you just keep shouting it louder each time i prove you wrong
perhaps if you spent more time applying what you learned in "Electronic Engineering with Maths & Semiconductor Physics" and less time quoting books you'd have more luck, just a thought here but you should take a quick look at what you've written and see, even if it's just to reassure yourself, that when you plug in the numbers that the formula actually works
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 27-05-07, 09:49 PM   #37
stuartyboy
calm down...pm'd
Old 27-05-07, 10:04 PM   #38
the_lone_wolf
Captain Awesome
calm down? i was just reiterating the main points of my argument whilst dispelling some of the inaccuracies in yours, the rolleyes were there because it's obvious enough to cause blindness that the formulae you quote don't work, so pretty frustrating to watch someone defend them without even trying them out for themselves
PM received, fair enough, i can understand why you don't want to debate the subject...
as for keeping the "insults" off the public forum, what insults are these? and does that mean it would be ok to insult you in private? - just kidding
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 27-05-07, 10:42 PM   #39
stuartyboy
I've edited out all my posts on this thread because of Lone wolf. I don't want to be associated with or debate anything this guy says.
A PM was sent to him and that should have remained private. Instead he publishes the pm on the open forum - totally out of order.
For anyone that's interested I have a motorcycle data calculator. It wasn't written by me but it works out all the rpms, speeds, wheel rpms, ratios for you. It's in excel spreadsheet format and works for any bike. Its also accurate.
If you want a copy then PM me.
Also there's a nifty calculator online
http://www.bikerenews.com/Stories_Ar...Calculator.htm
Old 27-05-07, 10:46 PM   #40
the_lone_wolf
Captain Awesome
The PM I sent you was private. You then respond by publishing details on the public forum. Cheap shot.
details? oh right, the insults, what were they again?
if you thought that was cheap perhaps i should get a few friends to send you threatening PMs, now that would be a cheap shot
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Theoretical Questions You Need To Know The Answer Too..... Welsh_Wizard Idle Banter 20 04-12-07 02:19 AM
2 wheel junkies body work? ? would you? John 675 SV Talk, Tuning & Tweaking 29 04-07-07 08:31 AM
Theoretical acceleration question Warthog Bikes - Talk & Issues 29 10-05-07 06:58 PM
Abba wheel spin.does it work? ged Ancillaries 8 03-03-07 10:32 PM
