Old 04-03-09, 11:46 AM   #451
Default Re: Bent Banana - The SV resurrection.
How do I know my dust deals are shot? I take it they are pence? Should I just order a couple anyway - anyone know what to ask for?
brake seals and anything else here
http://shop.wemoto.com/index.dyn?oid=1915475
where i got my last lot from, and various everything else for Suzy
Old 04-03-09, 11:47 AM   #452
Dave20046
Dave20046's Avatar
See if it will polish out, some autosol or brasso or something does the trick.
Make sure you clean all polish off with brake cleaner after.
Use rubber grease, put some in the seal grooves, install seal, press down on seals and wipe off excess. Smear a little round the pistons and install.
Cheers, I'm not sure you can tell from the photo but they are marks from pliers ...not sure they'll polish out. Guess I can make them as safe as possible though with a bit of fine henry cloth.
My floating disks travel a few mil too is that normal? I jacked it up and because the brakes were dragging when I moved the wheel side to side it made a right clunk.
Ta chris.
Old 04-03-09, 11:47 AM   #453
Dave20046
Dave20046's Avatar
Thanks dizzy
Old 04-03-09, 11:48 AM   #454
Er I hate to be pedantic, but why did you mark the pistons with pliers?
Old 04-03-09, 11:50 AM   #455
Dave20046
Dave20046's Avatar
**** I was trying to get away with you guys assuming it wasn't me. *hangs head in shame* Because there was no power in the braking, the pistons would not pop out how ever much I pumped the lever so I wrapped the pliers in inner tube and took grip and pulled them out. I thought I was being gentle but these marks (pretty damn sure they were caused by me ) were on them so I'm guessing the pliers punctured the rubber.
Old 04-03-09, 11:51 AM   #456
Ahh ok, like I say, try polish the marks out, if they won't then it's new pistons time.
Old 04-03-09, 11:52 AM   #457
Dave20046
Dave20046's Avatar
**** really? Nah they won't polish out I tried. If I can sand them down a bit so they don't feel sharp reckon they'll be safe to use? With the current pads I really doubt they even travel down that far for the marks to touch the seals.
Old 04-03-09, 11:54 AM   #458
Unless you get lucky and the marks will be above the level of the fluid seal.
Old 04-03-09, 11:55 AM   #459
pistons on the link too I think Dave
Old 04-03-09, 11:56 AM   #460
Dave20046
Dave20046's Avatar
Best find that ****in ruler
Cheers again chris
Bent rim! phil24_7 Bikes - Talk & Issues 18 01-11-07 02:51 PM
The worlds straightest banana gazman Photos 15 19-08-07 07:21 PM
Geostationary banana over texas philipMac Idle Banter 5 01-02-07 10:21 AM
2000 W reg naked tweaked banana for sale Sloth For Sale - SV's and SV related items 0 25-06-06 12:28 AM
Photos of my new VFR Banana... chutz Photos 28 03-09-05 01:52 PM
