#41 |
Right, had a chance to get in my garage now that I'm home. Che, you were totally right about the lack of need for a return spring. I was talking carp.
Checked my own set out and realised that I had done exactly the same in the end and not bothered with one .....doh. ![]() ![]() Having thought about it, the most likely reason there is a spring is to stop the brake light flashing on and off when the brake isnt being applied. |
#42 |
#43 |
Looking good. I think you mean the nuts on the shifter arm? Once you have it adjusted in a suitable position then tighten one lock nut against each end of the black arm itself. On the transmission end tighten the 2nd nut against the rose joint - ie towards the rubber cover.
Not sure if it's critical -but on the shift lever end of the shifter arm I instaled the other rubber cover on the rose joint. I had to trim the inner edge of it slightly to keep the joint moving freely, but I figured it was better to have it there and keeping road crap out of the rose joint, and and oil/grease in place. Last edited by CheGuevara; 01-05-09 at 08:33 PM. |
#44 |
Nice suggestion about the cover ...i'll do that to morrow
#45 |
Here's mine if it helps.
Looking for: LHS Rearset - 99 Curvy | JimmyGulp | Stuff Wanted | 6 | 04-07-08 03:41 PM |
Rearset bracket | plowsie | Stuff Wanted | 4 | 03-07-08 10:43 AM |
rearset Compatability | andyb | SV Talk, Tuning & Tweaking | 25 | 27-09-07 07:41 PM |
I designed some rearset for SV | r4ce_e3nd | SV Talk, Tuning & Tweaking | 16 | 10-11-06 09:59 AM |
Rearset fitting | rigor | SV Talk, Tuning & Tweaking | 4 | 11-12-05 05:24 PM |
