#41 |
another thing I thank my Dad for. I'm pretty pedantic about oil checks, tyre pressure checks etc (perhaps i should be about scottoiler connections.....)
#42 |
Badn luck matey
The oil light is not for the level; its for pressure. I check my oil quite often, and keep it topped up to the uppermost level (indicated by the line on the sight glass). I'll have a poke at the oil level tomorrow ![]() out of interest, what was the level when you had chekced it two weeks previously? Matt |
#43 | ||
Shame that low oil pressure catches so many people out. |
#44 |
Seen as only 2 perople have answered your 'How long?' question i'll add to this thread by being the third.
Whoever said one hour each way has either done it many times before or is so quick he's likely to be sloppy and miss somthing. Whoever said a day was probably about right for the first time you do it. Assuming you can get things like exhaust bolts out then a day is a realistic figure with your time probably being 1 1/2 to 2 hours getting it out and the rest of the time getting it back in. It's really not a difficult job and i've only ever done it on pointy's co with just a bank of carbs it has got to be even easier. Couple of things though. If the engine bolts are the same as the pointy version you will need a 23mm 6 point socket for one of the bolts. Suzuki take the corners off the heads so 12 points dont work. If you dont have any 6 points go and get a set up to 19mm and an extra 23mm before you start or you will be cursing the day you ever thought it would be a good idea!! Good luck. |
#45 | |
as for sloppy and missing things, the above methods preclude that, although I can't obviously speak for how others may work. ah I see, from experiance then ![]() Cheers Mark.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! Last edited by rictus01; 16-03-08 at 07:13 AM. |
#46 | |
Knob faced knobster
Yeah was the first time i'd done anything more than an oil change. All the bolts pretty much came out/off with no problems. I didn't rush through it as i didn't want to mess it up by forgeting to do something. The best bit was when it started on the 1st press of the starter button after the swap ![]()
2011 Speed Triple 1050 |
Remember Remember the 5th of September | fizzwheel | Idle Banter | 45 | 08-09-08 01:11 PM |
who remember the MZ | Frank | Bikes - Talk & Issues | 11 | 10-06-08 07:47 AM |
Remember this...? | -Ralph- | Bikes - Talk & Issues | 6 | 15-11-07 08:44 PM |
Check out this for crazy ...... guess these guys weren't physics majors | Kinvig | Idle Banter | 10 | 30-08-07 03:39 PM |
Check this Guys and gals | John 675 | The Madlanders | 7 | 19-07-07 12:52 PM |
