#41 |
I see, maybe I can stick a magnet to the sprocket. Could you post a pic of what your set up looks like, i've no idea how to fit the hydraulic clutch so need all the help i can get!
#42 |
I'll try to get some pics today. If not, it might not be for 2 weeks. I'm going out of town tomorrow.
#43 |
No worries mate, i'll need to gather all the parts anyway. Did you get an improved feel on the clutch after the conversion?
#44 |
not really. It's not bad, just different. It's also my first hydraulic clutch.
While it used to (dis?)engage almost as soon as I let out the lever, now it doesn't until the lever is almost all the way out. I adjusted the lever closer and have gotten used to it, but it's still a little different. It may be a little smoother too. |
#45 |
Looks like a little bending would clear the mechanism from the rotor.
Could someone with a GSXR front end conversion measure the distance from the wheel centre to the magnet on the OEM disc for me please? If i divide that figure by 4 i'll get the distance i need to set one magnet from the sprocket shaft centre. |
#46 | |
#47 |
So would i for that price! Wish i had seen that before buying mine, i assume it works the same?
#48 |
That's the only problem...I don't know!
#49 |
What speedo healer are you guys using?
#50 |
Ordered it - will find out in the not so near future.
speedo sensor | Apophes | SV Talk, Tuning & Tweaking | 2 | 30-01-08 09:25 AM |
Speedo sensor. | phil24_7 | Stuff Wanted | 4 | 06-01-08 01:56 AM |
Speedo sensor | phil24_7 | SV Talk, Tuning & Tweaking | 9 | 09-12-07 09:18 PM |
Speedo Sensor | djt_spurs | Stuff Wanted | 2 | 14-11-07 10:09 AM |
speedo sensor | husky03 | Stuff Wanted | 6 | 08-08-07 10:13 PM |
