Old 25-08-09, 09:32 PM   #41
madness
Default Re: rear shock change
Originally Posted by Bikermike59 View Post
Don't really fancy cutting it about to fit a new shock!
Any alternative?
Hagon Shock or something very expensive with a remote reservoir. Even a Hagon is over £200. A GSXR or ZXR shock is about £40-50.
Old 25-08-09, 09:53 PM   #42
Lucas
which one & year needs the least mod on a curvy? cheers!
Old 25-08-09, 09:55 PM   #43
A hagon is an emulsion type shock, not in the same league.
ZX6R B1H
Old 25-08-09, 10:05 PM   #44
Bikermike59
Better get the dremel out then!
Old 27-08-09, 10:35 AM   #45
Lucas
ZX6R B1H
so that is the 2003/4 one... is the 04-07 ZX10R 338mm 540# the same? (easy to fit etc)
are the later 05 onwards no good for a curvy sv650s (with me on)? only asking as there are buckets full of them on evil bay
(i'm a fairly standard height of 5'7 at 11st)
Old 27-08-09, 10:53 AM   #46
Luckypants
Luckypants's Avatar
Yes, virtually identical to the ZX6 B1H shock. I fitted one to my curvy - it was so much better than stock. Easy to fit, small cut to battery box for the reservoir and then raise battery on a foam block so it is not rubbing on the shock.
Old 27-08-09, 11:18 AM   #47
Lucas
sweet, thanks (logs on to e bay)
does sound easier to fit, have you got any pics of your crafty work? cheers!
oh, you can see my rear shock giving up at 1:58 (mind you it is 10 years old with 30k on it)
Old 27-08-09, 12:41 PM   #48
Luckypants
Luckypants's Avatar
No pics, but I seem to remember that Mister C did a photo step by step guide last year, try a search.
Edit: here it is... http://forums.sv650.org/showthread.php?t=113667 (fitting a ZX6R shock but the ZX10 is fitted the same way)
Old 28-08-09, 09:30 AM   #49
Lucas
eeer, I assume that a zx6r 05 onwards shock won't fit a curvy (as its not on the list)
Old 28-08-09, 09:34 AM   #50
CheGuevara
Check here near the bottom and compare with the rate and length at the top for the curvy http://forums.sv650.org/showpost.php...9&postcount=34
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
Shock spring change andyb SV Talk, Tuning & Tweaking 2 23-03-08 03:51 PM
To change the rear shock, do I need to remove the swing arm? DarrenSV650S SV Talk, Tuning & Tweaking 13 28-12-07 07:42 PM
sv 99-02 shock change French SV Talk, Tuning & Tweaking 4 24-02-07 07:47 PM
change of standard shock riktherider SV Talk, Tuning & Tweaking 17 14-12-06 12:48 AM
