Old 22-09-09, 08:39 AM   #41
Dave20046
Dave20046's Avatar
Default Re: Preload settings... yet again.
Originally Posted by madness View Post
What I can't understand is that when I increase my fork preload to achieve 35mm of sag, the front end felt like it was skipping about over bumps/irregularities. Not good when the bikes mid corner.
I get the same feeling over very choppy surfaces, not sure if that's due to the nature of the sv's forks or down to the progressive springs but the improvement far outweighs this from what I've experienced. Only time it's ever been an issue was the other day at the recue ride out we got a quick go on an airfield so I had some fun on the corners going up there the surface was really choppy concrete (like visible waves style) it was sfairly uncomfortable but I was cranked damn far over at 70mph+ . If we're talking about the same sensation then it may well be nothing to worry about other than comfort (although it might put you off round a corner).
I just set up my preload by adjusting it in accordance to travel (probably the wrong way as I didn't measure anything like I know you did), at the moment the preloads ended up maxed out and I'm just under a cm from bottoming out.
Sag and preload etc AndyBrad SV Talk, Tuning & Tweaking 12 20-06-09 06:59 PM
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. sv_rider1990 SV Talk, Tuning & Tweaking 12 11-07-08 05:15 PM
Preload Settings Giffer2 SV Talk, Tuning & Tweaking 5 11-08-07 04:25 PM
fork preload steveg SV Talk, Tuning & Tweaking 3 08-03-06 07:33 AM
Suspension preload for 2 up STRIKER SV Talk, Tuning & Tweaking 0 22-02-06 06:46 AM
