Old 09-11-09, 07:27 PM   #41
Default Re: Brake piston removal
Caption "ah so this is why you change brake fluid every now and again!"
Old 09-11-09, 09:02 PM   #42
Lucas
now they are all clean and shiny
Old 09-11-09, 09:11 PM   #43
xXBADGERXx
Lucas , how did you get the caliper bodies away from the Sliders ? (seen bottom left hand side and bottom right hand side)
Old 09-11-09, 09:18 PM   #44
boot
My front had a lesser amount of that carp in, doubt they had ever been done before.
My sliders just slid off, seemed to have a red-ish coloured grease inside the boots, but it wasn't 'red rubber grease'.
Old 09-11-09, 09:20 PM   #45
Lucas
they just slide out, the rubber thingys will pops off
Old 09-11-09, 09:22 PM   #46
xXBADGERXx
Ummm , mine don`t so I thought they were held in by some hidden circlip or something .
Old 09-11-09, 09:22 PM   #47
Lucas
think its a mix of both, red rubber grease for the inside of rubber thingy and standard grease for the slider bars.
Old 09-11-09, 09:24 PM   #48
Lucas
the rubber thingys + grease makes a good seal hence creating a suction effect. try popping off the rubber first.
Old 09-11-09, 09:30 PM   #49
boot
That makes sense.
Old 09-11-09, 10:52 PM   #50
beabert
they should just slip out, clean the bore the sliders go in, mine were full of crap.
Can't stop a front brake piston from leaking Heather SV Talk, Tuning & Tweaking 11 31-03-09 10:31 AM
Seized brake piston? xlewdx SV Talk, Tuning & Tweaking 13 13-11-06 09:49 AM
Rear Brake Pedal Removal??? MarkyBoy SV Talk, Tuning & Tweaking 6 12-08-05 02:15 PM
Help! Brake piston problem HKP SV Talk, Tuning & Tweaking 8 24-05-05 12:51 PM
2000 SV650S Rear Brake Piston Seal Tris SV Talk, Tuning & Tweaking 5 29-12-04 09:04 PM
