Old 24-11-09, 01:39 PM   #41
Holdup
Default Re: Electrical weird one.
Nice!
I work at a bike shop on Saturdays which is a datatool authorised dealer, so if you havent found the answer by Sat ill ask one of the guys and let you know as well
Old 24-11-09, 01:40 PM   #42
ophic
ophic's Avatar
Originally Posted by LK-SV View Post
I'm wondering whether sticking it on the indicator wire that comes out of the main fusebox would be a suitable place ??
The place I had in mind was the output of the indicator relay. However the fusebox wire might also be suitable - I don't have the circuit in front of me to check.
Silver SV650SK3, Fuel exhaust
Old 24-11-09, 01:42 PM   #43
LK-SV
Nice one Holdup !!! I'd appreciate that ......
I'll ask the garage if they've got anymore, and I'll post you one if I can get one .......
In the meantime ... keep that indicator off
Old 26-11-09, 01:25 PM   #44
LK-SV
Ok, almost finished this long journey ....
So, for anyone who has this problem in the future - it turns out its a simple fix .... and I'd recommend getting it done ... many a tale of blown fuses and fried electrics ....
1. Get yourself down to a Datatool dealer ...... and ask them for a diode ..... (cost me £2 for 2) .... but they said they've got hundreds knocking around, as each kit they fit comes with one, but most bikes don't need it - so ask nicely !!!
2. Fix the (only need one) diode in to the pale blue wire that comes out of the relay. The relay is the box that is fitted next to the fuse box (under the pillion seat on my pointy) ..
3. Test !!
Thats it ....
Thanks for all your help everyone - esp. Ophic ...
I've yet to fit mine .... but the datatool dealer talked me through it .... I'll confirm it works when I get the chance to wire it in ... but confident it will .....
Old 27-11-09, 09:33 PM   #45
ophic
ophic's Avatar
fitted it yet?
Old 28-11-09, 06:46 PM   #46
LK-SV
No - sorry - not yet ......
What with work, and no garage I'm not sure when I will ....... I will as soon as I can ........ but now I know I can fix it, I'm not so concerned !!
Old 12-12-09, 02:11 PM   #47
LK-SV
Soldered the diode in place this morning (along with a load of other connections that needed work)...... and result .... all now working a-ok ....
There wasn't much space to work on, for soldering the diode in place though ... so fingers crossed the solder holds it ok .... shrunk wrapped it in too ... so should be fine ..... but if my indicators ever stop working .. I know where to look first !!! lol.
Am I weird? Milky Bar Kid Idle Banter 67 23-10-09 10:04 AM
Weird Problem, Electrical mister c SV Talk, Tuning & Tweaking 8 15-12-08 11:26 AM
Weird electrical problems chakraist SV Talk, Tuning & Tweaking 18 17-11-08 03:52 PM
Am I weird? jumjum_0214 Idle Banter 4 09-03-08 09:43 AM
Bit of a weird one markmoto SV Talk, Tuning & Tweaking 2 06-08-07 11:10 AM
