Old 26-06-10, 02:52 PM   #41
Mr Meerkat
Default Re: stubby brake levers for k3... k9/10 fit?
hmmmmm, just got mine in post, the sv ones (see my first post on topic) brake is fine but the clutch lever not tripping the clutch sensor so can't even start the bike with it on....
anyone got any ideas? alternatively anyone recieved the gsr model ones? do they work....
they look nice tho...
Old 27-06-10, 09:42 AM   #42
beno987
did you get it sorted? mine will hopefully arrive this week.
Old 28-06-10, 11:05 AM   #43
BBadger
got my gsr ones and yup no hole for the clutch switch.
any ideas apart from removing clutch switch??
Old 28-06-10, 11:19 AM   #44
breakz187
I have received mine. Will fit in an hour, and i guess i'll have to bypass the clutch switch.
Old 28-06-10, 11:25 AM   #45
BBadger
But does that not cause fueling problems?? or am i remembering things wrong.
Old 28-06-10, 11:40 AM   #46
beno987
let me know how you get on, what you do to remedy it.
Old 28-06-10, 01:49 PM   #47
breakz187
bridged mine - had trouble fitting the clutch lever. I have the gsr600 ones. Had to saw/file a little part off of it to get it to fit properly. They work well.
Old 28-06-10, 03:55 PM   #48
Mr Meerkat
Which bit?
Also i just noticed some1 has asked if they're doin one that fits k3 def? they say ones comin soon, but i guess it's just a bit shonky.... oh well, negative feedback to the seller and complain i guess tho i bought supposed k9-k10 ones for a k3 BUT i checked part numbers for both years and they are the same... grrrrr
Old 28-06-10, 06:24 PM   #49
BBadger
I doubt any of them have the hole required for the clutch switch.
I though most over companies used a plunger like the front break switch.
File or drill seems to be the way to sort it...just compare it to the original and mark the point up.
Old 29-06-10, 11:23 AM   #50
beno987
do you have any pics of what you had to do?
Curvy Carbs, clutch levers and brake levers 21QUEST For Sale - SV's and SV related items 2 03-03-10 11:04 AM
clutch and brake levers in red Tristec Stuff Wanted 8 11-07-09 08:57 PM
stubby brake and clutch levers? stuballs SV Talk, Tuning & Tweaking 19 18-01-09 01:27 PM
Brake levers smegmunky SV Talk, Tuning & Tweaking 4 04-06-07 01:52 PM
Brake levers plowsie Stuff Wanted 3 26-05-07 07:53 AM
