#41 |
The sort of middle ground is to get proper cartridges fitted.
#42 |
Call Hagon's a temp fix while I save and decide weather to cartridge, voodoo or gixxer the front end.
#43 |
Voodoo is cartridge conversion.
#44 |
"Those nitron track/race ones, piggyback res? That seems daft to me, if you are making custom shock put it on a hose so owner doesn't have to chop bits up."
Although I am very pleased with my nitron track piggyback res shock with hindsight I would have gone for the remote reservoir. As Chris points out, the piggyback version can be a bugger to install (I had to cut off the tool box in order to allow enough space for the shock). I was also a little annoyed that nitron decided to change the position of the compression damper from the more accessible left hand side to right hand side of the bike. When you receive your nitron shock it would be interesting to know which side your comp adjuster is facing? Whatever, you won't be disappointed with the build quality while it will transform the handling of your bike. Enjoy! |
#45 | |
ive just fitted the hagons in mine along with a zx636 rear shock, not ridden yet but will give a review later if i manage to get it all back together today and the road drys up a bit. first impressions from sitting on it in shed thou, give a hard front end and a low back end. not sure if this rear shock has height adjustment, but at the mo it feels a lot lower the before. which should make for easier knee downs ![]() |
#46 | |
I THINK your shock is 330mm, and the standard curvy is 337mm (somebody correct me if I'm wrong). You could do with getting some brackets made up to lengthen it. PM Icanopit, he has a Kwak 636 shock too and has done this, he may be able to give you his design, and the details of the people who made his for him. Last edited by -Ralph-; 13-02-11 at 09:36 AM. |
#47 | |
#48 |
What year 636 shock?
#49 |
05-06, ive put the shock on as it come to me with a view to adjust it as needed, the preload is set with the coil right near the top(is this min or max). its not 'that' low but enough to feel the difference to standard
#50 |
Adjuster rings at the top is minimum preload. You'll need to wind it down a fair way, try get to about 10mm of bike sag.
SV650 K6 shock & GSXR1000 K4 Shock | weecorey | For Sale - SV's and SV related items | 0 | 03-05-09 08:02 PM |
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? | Paul the 6th | SV Talk, Tuning & Tweaking | 37 | 31-10-08 12:26 AM |
M10 55mm Shock bolt and nut for Kwak Shock | Mr Speirs | Stuff Wanted | 3 | 24-10-08 12:00 AM |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) | alien19779 | For Sale - SV's and SV related items | 0 | 28-03-06 01:16 PM |
