Old 18-05-11, 02:37 PM   #41
formula400
Default Re: R6 throttle tube, is this the part number?
hmmmm now this sounds good, think this is the next mod.
Old 18-05-11, 02:51 PM   #42
Default Re: R6 throttle tube, is this the part number...
Originally Posted by Daveo2010 View Post
I've googled those part numbers but don't see anyone actually selling them in the UK - do you buy from a local Yamaha dealer or something?
Ta,
D
Err yes
Old 18-05-11, 03:15 PM   #43
Daveo2010
Err yes
Hehe ta
<-- online shopping addict/shut-in
Old 18-05-11, 11:24 PM   #44
NTECUK
NTECUK's Avatar
http://www.wemoto.com/oem/
if you cant be a##d to go to the shops
t
paste the part number lower right of the screen
Old 19-05-11, 01:36 AM   #45
T0mmyGun92
I've fit one of these onto my pointy sv650 (bought off ebay posted for about £ and it makes a nice difference. Drilled off the small bits off of the throttle stops on the tube. Can actually hit full throttle in one twist, but if anyone else is like me and wants that little extra oomph off the line try what i did. I bought one of these, installed it, 2 days later wanted more so i got a cd and cut off a small semi circle which i glued into place in the slot where the throttle cable initally runs... makes it pull through the low end revs stupidly fast and then have the throttle length at the top end that you normally would with this tube. Couple this with a race can and an easy flow air filter and you'll pull easy sat down 2nd gear power wheelies when you pin the throttle
Old 19-05-11, 09:16 AM   #46
Daveo2010
t
Ace - ordered today from Wemoto, lazy so-and-so that I am. I'm looking forward to this mod, I think it'll make a lot of difference given that I pretty rarely do the hand shuffle to full throttle with the stock grip.
Old 19-05-11, 10:28 AM   #47
formula400
t
wicked cheers dude, £19.49 posted for tube and grip for other side
Old 19-05-11, 11:07 AM   #48
Whitty
Sounds like a bargain. Don't suppose this mod fits old srad gsxr 600 carb models?
Old 19-05-11, 12:13 PM   #49
NTECUK
NTECUK's Avatar
I read that strad thread too. So some gixers it wil.
Old 21-05-11, 11:48 AM   #50
Daveo2010
My grips arrived today and I've already lunched the right bar end screw - don't even try a screwdriver... the bolt is made of edam.. straight at it with the impact driver and the left came off easy as pie. Off to screfix now for some easy-outs and see if they can match the bolt
[edit] Only the head is made of cheese! I broke two drill bits and wore down the thread on one easyout, but it came free eventually [/edit]
Throttle Tube (K3) Hoody90 Stuff Wanted 13 16-03-11 06:44 PM
The R6/R1 throttle tube on SV - what does it do? danf1234 SV Talk, Tuning & Tweaking 4 24-05-10 07:55 AM
Need a new throttle tube TightRS SV Talk, Tuning & Tweaking 2 23-12-08 10:13 AM
R6 throttle tube Quiff Wichard SV Talk, Tuning & Tweaking 34 04-06-06 08:42 AM
R6 throttle tube for a K4 SVeeedy Gonzales SV Talk, Tuning & Tweaking 0 04-01-06 12:22 PM
