Old 22-04-11, 08:11 PM   #41
daveyrach
Default Re: Car Horn on SV?
Just ordered one from Larkspeed, was actually cheaper.
Old 16-05-11, 09:00 AM   #42
daveyrach
Finally arrived £7.99 what a bargain!
Old 16-05-11, 09:42 AM   #43
warmshed
Halfords have now discontinued the magnum horn so worth checking if they still have one at your branch, they are selling them for £5.. if they still have one.
Fitted mine yesterday, on the curvy, needed to extend the wires about 3 inches, did not use a relay, not required for one horn (needed for the nautilus air horn). Found it better to use existing bracket as it is shorter than the one supplied with the horn. Make sure that it cannot vibrate and touch the radiator.
Old 16-05-11, 07:46 PM   #44
If you add enough horn that you need a relay a SPST type (4 pin) is fine, you want the normally open variety. SPDT (5 pin) is also fine and is the one usually listed as universal.
No Horn pin64 SV Talk, Tuning & Tweaking 1 19-07-09 12:11 PM
The horn Kinvig Stuff Wanted 6 18-08-08 12:15 PM
Got the Horn? metalmonkey Idle Banter 0 24-10-07 04:57 PM
Are you getting the Horn? DanDare Bikes - Talk & Issues 3 06-07-06 12:56 PM
Get the horn northwind SV Talk, Tuning & Tweaking 44 02-03-05 12:22 AM
