#41 |
Sealey VS1806 - Motorcycle brake piston removal pliers, they cost around £10 now I think.
#42 |
The large diameter pin on which the upper end of the inner pads sits often has a notch worn into it by the pad, that's not a problem really as it's easily fixed - run weld into it and grind/file back to size. What I was referring to is the interface between the caliper bracket - that allows the caliper to slide side to side - and the caliper body, the holes in the aluminium of the caliper body wear oval, and that's wear that isn't easily addressed.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 18-11-08 at 03:02 PM. Reason: Missed a bit & spelling! |
#43 |
Thanks SS, I'll look for that before starting the rebuild.
Edit: Ta DD, I'll have a look for a set as there's a pretty comprehensively stocked Halfords near me. |
#44 |
#45 |
Does copper grease?
#46 |
i wouldnt put copper grease around your seals, just stick with red rubber grease and youll be fine
#47 |
Wemoto also do a complete rebuild kit for each caliper, plus I think you get a tub of red rubber grease with the kit. Stainless pistons too included in the kit i think
Don't know how their prices compare with Fowlers, but their service is great. http://www.wemoto.com/
#48 |
Don't use copper grease on seals.
#49 |
#50 |
is it going to be an issue?
Rebuilding the SV fighter. | Grinch | SV Talk, Tuning & Tweaking | 34 | 27-08-09 05:44 PM |
Rebuilding Front End - 2002 Curvy | slloyd | SV Talk, Tuning & Tweaking | 24 | 14-05-09 03:18 PM |
Rejetting and Rebuilding carbs . help | drag | SV Talk, Tuning & Tweaking | 19 | 26-01-09 11:27 AM |
Rebuilding '03, Need: forks, radiator, headlamp | Broncstang | Stuff Wanted | 0 | 13-11-07 03:23 AM |
rebuilding SVS, do I have a choice of motor? | dizzzzz | SV Talk, Tuning & Tweaking | 1 | 14-01-07 02:38 PM |
