Originally Posted by jambo
Originally Posted by BigApe
Troublesome thing is, he will have stripped down the bike in order to complete the compression test. If you decide not to have the work done, then find that it does need doing after all, he will charge you again for the same work he has already done.
Assuming he's just using a normal compression tester of the type I've seen on sale at Halfwits all you need to do is pop a spark plug out, press the compression tester in the hole left by said plug and turn the motor over. Doesn't seem like a lot of work
Then, what do I know never done a compression test in my life
I meant as in took all the faring off etc. Not actually stripped down the engine. Should have worded it better I guess.
