Old 25-04-10, 11:12 AM   #61
barwel1992
Default Re: Which GSXR forks etc? (Yet again).
ohh right thought they were nissin but ure right they are tokico, the the ones he thinks he had (97/9 had the 4 pot callipers and the 43mm stanchions
the bearing spacers is not the twf one is it ?
Old 25-04-10, 12:49 PM   #62
davepreston
twf one is the reverse of what you want to get
Old 25-04-10, 12:54 PM   #63
barwel1992
lmao im sooo confused, so the gsxr 1100 forks dont just drop in a pointy ?
do i need a bearing or a spacer or both ?
if the twf one is the reverse do i need the original gsxr 1100 head bearing ?
Old 25-04-10, 12:55 PM   #64
davepreston
Old 25-04-10, 01:01 PM   #65
davepreston
lmao im sooo confused, so the gsxr 1100 forks dont just drop in a pointy ? no stalk size is different
do i need a bearing or a spacer or both ? one or other ,use a spacer with standard bearing or get a new bearing with smaller internal diameter but same outer diameter
if the twf one is the reverse do i need the original gsxr 1100 head bearing. twf bearing makes internal diameter bigger not smaller ?
hth
yc im sure will be along to confirm
Old 25-04-10, 01:04 PM   #66
barwel1992
cheers Dave
just a few questions
i presume they work ? (lol)
do they leek?
wheel straight ?
yoke reinforced for the risers or was it not needed ?
forks straight?
any idea if the steering lock would work ?
cheers
what about fitting the gsxr1100 bearings to the sv ? GSXR 1100 head bearings and do i need to do the bottom bearings as well or just the top ?
sorry about all the questions
Old 25-04-10, 01:49 PM   #67
davepreston
cheers Dave
i presume they work ? (lol) yes
do they leek? new seals needed
wheel straight ? yep new tyre needed
yoke reinforced for the risers or was it not needed ? not needed
forks straight? yep
any idea if the steering lock would work ? see yc's post earlier you need to put on steering stops on all gsxr conversions but it apop
cheers
just top with spacer (gsxr1100) , or you need to find a bearing with your stalk diamiter as the inner diameter of the bearing but gsxr 1100 outter diameter (new bearing on bottom comes with it but id buy matching)
Old 25-04-10, 01:57 PM   #68
barwel1992
thanks for the info, might be biting off more than i can chew with the seal's and things as the forks look very complicated to strip, also sourcing the correct spacer is proving difficult
im going to have to wait till i get my bike back to decide what i want to do, regarding forks and stuf
so if im still intrested i will let you know
Old 25-04-10, 01:59 PM   #69
davepreston
no worries
Old 25-04-10, 06:19 PM   #70
barwel1992
im still interested in the forks so would i be able to take a look when your in leam spa ? will bring my old man with me to have a look as well
only thing that's bothering me is getting the spacer for the bearings, will get the forks serviced professionally so seals ant a issue
Fitting GSXR front mudguard to GSXR USD forks maviczap SV Talk, Tuning & Tweaking 1 20-02-10 10:05 PM
GSXR 750 k4 wheel with GSXR 600 K7 forks Bunks Bikes - Talk & Issues 12 05-05-09 06:36 PM
K7 GSXR 600/750 or K8 GSXR 1000 Forks shelleyamy SV Talk, Tuning & Tweaking 17 04-07-08 07:51 AM
GSXR 600 K5 forks gruff SV Talk, Tuning & Tweaking 4 17-04-07 09:36 AM
which GSXR for forks svrash SV Talk, Tuning & Tweaking 29 15-02-06 09:15 AM
